Has anyone came across an extra metal piece on the coolant flow line that goes in valley? Seems to be holding harness away from line and engine. So I guess I have 4 nuts to remove instead of just two ,to remove that line.There's actually two holding it on back there. A real pain. Usually a 1/4" drive ratchet and socket works. Once they're removed you just pull rearward and the pipe will come off the front nipple.
Then you do need to remove the inboard bolt / stud to remove the coolant line. For the outboard bolt / stud, you only have to loosen it in order to remove the coolant line.
They unscrew .
