Removing air intake piece on 06 model
kevdawg
Fort Lauderdale, FL
I'm having a hard time finding any instruction on how to remove the intake on my model/year.
Can anyone help explain how to remove this portion?
I am able to remove the other end from the air box just fine but can't figure how how to best detach this from the black plate it's connected to underneath it.
Another view of the connection to the black plate from below:
Thanks!
Note: We are having intermittent acceleration problems and just want to check inside here to be sure there aren't leaves or something stuck inside. Also, we're getting ready to do the gott's mod, but need to figure out what is causing the acceleration problem.
sgtowing
Supporting Members
Valrico, Fl
If I remember correctly, it just pops in. It like a friction fitting. It should be able to lift straight out.
Sent from my SCH-I535 using Tapatalk
Stoned06
Milwaukee
It pulls out from the fender, and pops up to disengage the rubber grommets.
kawi_200
Everett, WA
Exactly what I was going to say. It was very easy to pull up for me. I took it out of the throttle body area then lifted straight up.
K
kevdawg
Fort Lauderdale, FL
Cool! Thanks for the replies and then confirmations.
I will try it again with less worry of breaking anything.
EDIT: I did try it again and it worked great! Thanks!
booksix
Nashville, TN
I know this is an old thread but I recently picked up an '05 and was curious what this big part of the intake tube is (considering the filter seems to be the front load square one downstream from this). Also, is there anything that would prevent me from removing/relocating this part of the intake tube? I'd like to try and fit a second battery in this location.
Boose
2017 Platinum EL
NJ
I think it is part of an "Air Silencer"... any aftermarket (K&N) filter kit ditches it usually. take it off and start the truck... you'll hear the rush of air entering the engine.
booksix
Nashville, TN
Thanks, I figured this was the case! Now I just need to figure out how to route the intake around a battery and still get outside the main engine compartment! :p
Boose
2017 Platinum EL
NJ
You don't need to route it outside of the engine compartment. The cooler air does help with power however. For example, this K&N kit replaces everything but sticks the filter in the open air of the engine compartment:
Jb14
California
On thing to consider is with the MAF (Mas air flow sensor) it is very particular to airflow if you take out the filter in the box and look inside you will see that on the underside of the top of the box there is a formed scoop and the MAF slips into the side of that any alteration to that scoop or changing how the airflows over the MAF will create a rough engine or engine that will not stay running. I have ran the stock and after market boxes and besides a throatier sound you will not see any advantage from a stock motor set up. Do you research before you purchase you will get more out of exhaust (again on a STOCK motor)
booksix
Nashville, TN
Yes, Boose, I just figured if I'm building something I'd like to keep that cooler air source... but we'll see if it's realistic!
jb14 - thanks. I'm not to worried about the MAF as I will only be modifying the system way upstream and outside the actual airbox (which will remain stock) - basically at the joint near the far left of the first image in this post (removing the silencer and replacing with tubing). I'm not actually buying any aftermarket system, just making room for a battery to run some in-cab electronics when on the road (engine off, deep cycle, etc) (Y)
Roxboro nc
i have a 06 ford expedition my question is I I remove the right side of the air cleaner tube where it goes into the fender would that help get more air power/fuel? And would it mess anything up?
Jb14
California
I have done all of that with no change in performance in fact pulling the tube from the fender gets less cool air and creates more heat as you are pulling air from the engine compartment. The stock configuration is pretty efficient. Some may argue but real world no change. If you really want to create a few more HP then get a better breathing exhaust system, and if you want to use a cool air system (which is mostly more noise) then have your computer adjusted to accommodate.
SafariGoneWrong
Mableton, Georgia
The only downside to the air cleaner pipe picking up in the wheel well area is that it provides a nice path for vermin to get into the air cleaner plenum. Lots of chewed acorn shells in there…
