Replacing Rear Axle
mjp2
Howell, NJ
Anything's possible with a skilled fabricator and enough money.
The 07+ Expedition has an independent rear suspension while the F150 has a solid rear axle. It'll be a full custom setup.
Leaving out the details, remove the stock stuff, cut out all the mounting brackets, get the new axle positioned in place, figure out what leaf springs might work and where, fab up places to mount the spring mounts, weld on spring mounts, figure out what shocks work and get them mounted, measure/order a custom driveshaft, plumb the brakes, figure out the parking brake setup, make sure the computer is happy with the new setup, test and tweak, etc.
You could alternatively go a 3- or 4-link setup and use coilover shocks, which would involve fabbing a crossmember and link mounts to keep the axle positioned under the truck instead of using the leaf spring setup. That approach will require stripping the F150 axle of all the mounts and welding on new stuff once you sort out the geometry and position of the links and mounts.
What are you hoping to accomplish through the swap?
Moose McClatchie
Salem
I was looking to get away from the Independent rear suspension. I hate the way it feels when I’m towing my trailer. I use WDH with anti sway but I can feel the rear dancing as I call it back and forth not a lot like a tail heavy load just a little back and forth movement. I find it annoying.
AllBoostNoEco
GA
The biggest problem is the shape of the frame. The IRS is what allows the totally flat interior when the seats are folded and the lowered load floor compared to the SUVs with a solid rear axle. There’s no space for the rear axle to move up and down in the Expedition as the frame is nearly flat and doesn’t have the “kick up” that the F-150 does to make space for the axle tubes. The rear axle shafts go through the frame, so you would have to do some significant work to eliminate the pass-through for those and retain the frame strength. The driveshaft tunnel is also not designed to allow movement of the driveshaft, so if you physically got a solid axle under the truck, there would be clearance concerns with that as well. As @mjp2 stated, anything is possible, but I’d wager you’d be halfway to a good Super Duty in the costs to get it under the truck. These trucks are simply not designed to accommodate a solid rear axle so it would be a total re-engineering job.
Hellwig makes upgraded sway bars for our trucks (front is 7696, rear is 7688), they may help somewhat. Upgraded rear shocks and load range E tires are other possible options to improve the towing feel.
07navi
Mt.Shasta California
Forget about putting a banjo in it. Ford dropped the floor in the back which took a lot of engineering and it required the independent axles, unless you want to give it a 6" lift or something.
Moose McClatchie
Salem
I guess I will just go buy a new F 150 it sounds like it might be cheaper lol. I’ve upgraded the tires and shocks. I will look into the sway bars. The reason I bought this was the seating capacity with a 9000 pound towing but it just feels weird when towing I eventually get use to it just takes half a trip to re a quaint myself with its idiosyncrasies
grdsman
Colorado Springs
I tow 7500 pounds. Use a good weight distribution hitch, anti-sway and upgrade your shocks. I put Bilstien 5100’s on and it helped the rear end feel a lot when towing. Or follow the instructions above. LOL
Moose McClatchie
Salem
I will replace the shocks soon and then see how it feels. My last tow vehicle was a 2001 F 350 that rode like a tank until I put my 15000 pound toy hauler on it then it was comfortable. The family got bigger and the toys went away so we bought an expedition and 1/2 ton towable trailer. Other than the wonky ride while towing I love this truck so I will just Ned to get used to it.
07navi
They should bring back the Excursion. 3/4 ton chassis, seats 8, Diesel option, Tows big stuff.
Yea, I towed my Navigator home on a trailer from 100 miles away over the mountains and it barely knew it was back there.......gas V-10.
mbtech2003
capecod
I would step up the tire to a c or d load range. Most likely you have a p load on there. The stiffer side wall will help out more.
Moose McClatchie
Salem
I have an e rated tire that was the first thing I did. I upgraded the shocks after my second trip not to the bilsteins though.
Defyant
Rising Sun Md
Any updates? I feel the same way about our new 2022 Timberline. Love the truck, not the swampy feel when towing. Heavier tires and sway bars are on the short list.
JasonH
Houston, TX
E tires and 65 psi will improve stability.
Timo2824
Wichita
I would just say get used to it, nothing wrong with it just a different feeling. I feel it too, but you do get used to it. For what it's worth, I have a 2007 explorer with independent suspension and I don't get the sensation while pulling the exact same 5,000lbs trailer. I think the bigger rims, my expedition has 20's, causes some of the feeling.
