Reverse Lights Don't Work
TN_XLT
Tennessee
My reverse lights stopped working. I checked the 20A fuse in the passenger foot well. It is good. I read that the Safety Neutral Switch down on the transmission shifter is a possible culprit for this type failure. How do I check this switch? Thanks.
sgtowing
Supporting Members
Valrico, Fl
Turn the ingnition on, not running, put the emergency brake on and use wheel chocks and put it in reverse. Get under the vehicle and check to see if you have power. If you don't, thats the problem.
Hampton, VA
change the bulbs...make sure your getting power to the socket as well
T
TN_XLT
Tennessee
I don't have power to the back-up light socket. I replaced the SNS and still don't have power to the sockets. I re-checked the fuse (#10 position 20A). It is good. Any other ideas?
sgtowing
Supporting Members
Valrico, Fl
Not the neutral safety switch. The reverse sensor on the tranny itself. It should have two wires on it.
Sent from my DROID BIONIC using Tapatalk
T
TN_XLT
Tennessee
I was told the SNS is a multi-function switch that controls the back-up lights when the transmission selector is put into the Reverse position.
If you crawl under the vehicle behind the driver-side front tire, here is what you see:
attachment.php
Where is the reverse sensor?
T
TN_XLT
Tennessee
Well I can't explain what happened...but my backup lights now work fine. It is possible the make-shift pigtail I made for the backup light socket didn't make connection when I checked using the mulitmeter. Regardless, looks like the switch on the transmission solved the problem. On to the next problem...
the_plugger
