Roof hump
Shakeandbake
Somewhere
Got a 22' Timberline and noticed that one of these humps are shorter than the rest. Just wondering if it's the same for all of you. I don't see any wiring or anything installed under that area, so not sure if this is by design or a mistake.
99WhiteC5Coupe
There has been one or more other posts regarding this observation on this forum - you may want to do a search.
If I recall correctly, the roof trough design was changed sometime during the 4th generation model manufacture.
LazSlate
Arizona
I have a 22 Timberline Q2 manufacture without that short hump. Maybe they changed the design to accommodate something in 23. Do you know the build date? Or its for some option you have or dont have.
SyndicateZ
Mass
ithe gap between your rear spoiler and roof is uneven it seems too
99WhiteC5Coupe
If the roof gap between it and the spoiler is uneven, read this: https://static.nhtsa.gov/odi/tsbs/2023/MC-10232437-0001.pdf
And
5280tunage
colorado
yup, get that rear spoiler checked. Good thing you don't look at your roof often, that would drive me crazy. To me if you have to shorten that for something on the interior, at least make it the same on both sides. Shorten the outer crimp on the other side too.
S
Shakeandbake
Somewhere
Ouch. Thanks for the call out on the roof spoiler. I've read all the warning on this forum for the 22' but the stupid side of my brain kicked in and bought it anyway.
My build date is 11/2022.
nationalgallery
I think that hump is probably the designer's attempt at an artistic statement.
  • Ballard 16-04:01.jpg
expeditiondriver
Have we figured out if this change in the roof is date related, factory related or model related specifically?
RacerBX1
SE Michigan
I have 2023 Timberline, built 12/22 and I do have the short rib on the passenger side of the roof as well. No idea why it’s like that. Maybe the die for the roof stamping got damaged and this is what they ended doing for the repair.
GlennSullivan
NY & FL
Another Ford engineer or group of same that could be given pink slips with nothing but positive results. There was nothing was wrong with Gen 3 rear hatch design / actuation in any kind of weather.
sjwhiteley
Kentucky
That short rib is bizarre…the only reason I can think of is an unseen design change which required it.
SyndicateZ
Mass
Its a manufacturing defect. I feel like someone failed to inspect (quality issue) that roof before the robots installed it.
MTB2022
livonia Michigan
Is it only on the sunroof/moonroof cars????? maybe different stamping because of interior structural differences.
BSarchet
Little Flock, AR
22 expedition max, was built in June and I don’t have one that is shorter. They are all the same.
Bennifer88
Charlotte, NC
That is strange it is shorter than the others. I have a 22' Timberline and mine are all the equal longer length. My build date was 5/22 and bought 7/22. I will be curious to see what you find out.
