Rough idles and dies
S
sffdib
California
From the start there was no check engine light, and no store codes. Everything we changed was based what could cause the problem. It was not verified in any way.
Yupster Dog
Super Moderator
Super Moderator
To be honest that really sounds like a intermittent ground lift. Do a visual inspection where the negative battery cable connects to the truck.(remember that it has been known to corrode under the wire insulation where you can’t see)
Maybe even give the wire a wiggle while running (if possible) to see if you can duplicate symptoms.
