No clutch packs in rear diff?
Yes, for Limited Slip.
There is nothing physical inside the Center Diff deciding percentages of Torque to distribute, and so forth.
Engaged, means 50% Forward.
Found out what’s likely causing my rumbling. So with the steering wheel centered I’m dead in for alignment. However with the larger tires and the spacers when I start turning at low speeds (below 15) the tires are actually being pushed due to the changed suspension geometry most likely caused by the Readylift 3/2 kit. Not sure if there is a fix for this as alignment is measured for when the wheels are pointed straight. Any thoughts? Are there maybe Different alignment specs for lifted vehicles?
No, The 3/2 is already pushing the geometry of the A-Arms. It is because of the Independent Suspension.
A relocation bracket or longer A-Arms would be the solution, but nobody is going to build a long travel kit for these trucks.
I’m going to take my spacers off and see if that helps. Will also be looking at brakes like someone had suggestedWhen I lifted my 06 I had to play around with a bunch of F150 aftermarket parts but I eventually found a combination of parts that worked to hold alignment and a mostly-normal ride. It was a real PITA, and was straight up trial and error; installing parts road testing, removing, and trying again. It helped that I had a friend who was a shop manager at the time so I got to use his lifts, tools, and alignment scanner after hours.
It's why I am hesitant to lift the 17 now. But I'm rooting for you to find a solution so I can copy you
I'm wondering if you read or viewed any of these references that explain how it works?Yes, for Limited Slip.
https://en.wikipedia.org/wiki/Ford_Expedition#Four-wheel_drive_system
https://en.wikipedia.org/wiki/ControlTrac#The_Modes
https://www.designnews.com/automotive-0/4-wheel-drive-steps-back-future/143802243139748
https://patents.google.com/patent/US5485894A/en?oq=5485894
