Spark Plugs, no more BS
KerryP
Sacramento, CA
Ok..so I’m a girl, and I did the passenger side bank last night. (Rain hit before I could do the passenger side).
I had to rig an extension because the extensions I had weren’t going to work.
It’s still raining today, but I can happily post pics or a video of my extension and removing the plugs and coils.
Bain64
But this can't be. I read earlier in this thread that it is impossible to change the plugs! How much of the body did you have to cut to get to the spark plugs? /s
Anyways.. Good work! I hear the passenger side is worse, hopefully the driver's side goes easier for you. I'm planning to tackle the same job within the next couple weeks. Do tell about the rigged extension! I've got several elbows and wobblers so it should be ok, but tips are welcomed.
Just curious what you guys/girls are using to start the new plugs in their threads? I've liked a hunk of tight fitting fuel hose to start them.
Big Brian
Farmington Hills Mi
I have an old spark plug boot with a long bolt jammed into the end where the wire would go for a handle
I am talking about a standard spark plug boot from and old car engine, not one of these new style ones
nice thing about it is its flexible since the boot is made from silicone rubber
and0r
and0r
CA
... do it
KerryP
Sacramento, CA
Ok..i braved the rain and finished the drivers side. I noticed that i wrote passenger side 2 times yesterday...i was tired. So, drivers side is by far harder to get to the rear plug. The engineers clearly had a sense of humor when they designed it.
Took a wobble and a standardish med/small extension and little hand to weave through all the lines to get to the rear plug. The front plug- removed the bracket on the steering resevoir it was only three bolts and took like 3 minutes to do.
I have a picture i can share of the extension down in the hole. Its not an ideal picture, but im fairly sure that if youve looked at one of these enough you will be able to figure out where the camera was pointing and at what.
I'm impressed, no scratch that, I think I'm in Love!
nonsense
PNW
I remember doing the plugs on my '03. I think I still have some scars on my hands from that (not to mention some emotional scars from thinking I'd never get those damn plugs out). I also remember blowing a plug out while driving in the middle of Yellowstone NP, good times.
and0r
and0r
CA
Ok - so nobody is going to identify the components in my pic... cool.
Where can I get a large flat pan to drain the radiator?
Jerry 2
Lubbock, Texas
There have several good ideas given on this post to make the job easier.#1 Engine cold. #2 pull the hoses out of the way and secure..#3. I used a plug wire pliers to remove coil. (some that were really stuck, required some twisting and prying.) I used a long air nozzle to blow any dirt and crud out of the plug holes . I sometimes used a Craftsman 3/8 drive sized air ratchet the size as a 1/4 ratchet but with a 3/8 mandrel. Use only arm power to break the plug loose then use air to unscrew the plug. ( Ford says do not use air power.) Check the plugs to see if there are any carbon tracks down the porcelian of the plug. I would replace all boots if there is tracking. Use dielectric grease inside the boot. Check the plug gap on all plugs, (Yes they are new but check them any way).I used a vacuum hose about 8 inchs or so long ,shove the hose over the wire end of the plug and use the hose to screw the plugs in place. If you are new at doing this job use a torque wrench to tighten the plugs.9 They can be over tightened as well as not tightened enough. I know I have already posted on this post, I just hoped I haven't led some one astray. If you had a miss before you started this repair, isolate the cylinder that's missing. Pull this coil and plug first, Check plug for trackling. Replace the plug and boot and see if it still has a miss, if it does swap a coil from a cylinder that is not missing. when re installing the coils and boots use dielectric grease on the boot where it slides into the plug hole, this will help keep water out of the plug hole.
DontBeJeff
Cary, NC
I am about to change the gasket to the intake manifold to see if I can get rid of my lean condition once and for all. I have read that is a great time to change out the plugs/coils, being you actually have to remove everything to get to it. There is a great video available of someone showing what to do to get to the gasket.
No members online now.
Landsbutter
