Speedometer Calibration
bsamc2000
Ohio
I am look for information on how to calibrate the speedometer on my expy when I get my new tires next week.
I have called 3 dealers local to me and they all say you cannot change this.
Any information would be greatly appreciated.
walnuts4x4
Watertown, NY
a programmer will do it in a matter of minutes.... 97-98 expys need a new gear placed into the speedo with a different tooth count, however a 99+ needs to be programmed it a programmer.... my personal choice would be the Edge CS... but hypertech, diablo ect... all do the same thing... besides speedo adjustment the programmers also improve the shift points and increase HP and MPG...
walnuts4x4
Watertown, NY
also what size tires are you going up too? up to 33-35s the speedo will only be off a little bit but 37s+ will cause a greater difference in the speedo... another cheap way to see your accurate speed would be to use a GPS and compare it to your speedo
tonydiv
technical advisor
Middle River, MD
Also remember the down side of calibrating the speedo... accurate miles on the odo.
My truck is off by 6mph at 60 (10%) meaning that I have 10% fewer miles showing on the odo than the truck has actually driven. If you're thinking of selling it in a couple of years, those miles can make you a few extra $$$.
bsamc2000
bsamc2000
Ohio
I'm only going with 285/75/R16 (33.2") for now. I know the speed will only be off a little but I would still like to upate it.
So if I get something like the Edge CS and change the size there do I need to leave it installed at all times to correct the speed?
Thermo
technical advisor
If you are only stepping up to 285's, this can be accounted for in the stock computer. The dealership just needs to get in and adjust a single value. It will cost you about $80, but it will save having to buy a new computer and setting all that up. But, like others said, you can get an aftermarket ECU and then reprogram that to exactly what you want.
There are also modules out there that you can tie into the VSS sensor (what reads the speed on the output of the tranny) and this calibrator box will alter the VSS signal and make the speedo read right too. The big problem with this box is that you have to splice wires together to make it work and the use of stuff like Raychem tubing (WCSF-070 tubing) is a must to ensure longevity. The Raychem stuff actually seals the shrink tubing to the wire insulation, making for a water tight seal. if you are worried about it failing due to being under the truck, DON'T WORRY. This is the stuff we use at my work to survive a nuclear reactor blowing up. It is good stuff.
Remo
Hartford, CT
I'm running the same size tire. Unless you want a programmer for other purposes, I wouldn't bother. It is easy enough to remember to add 10%...
panda24619
San Diego
its not worth it. your fine. it really wont be that much of a difference. just know where those road signs that show you the speed are and drive threw it. then you know the difference.
Remo
Hartford, CT
His truck is stock and has 16" wheels. If the tires are factory spec, they are 255/70/16 (which is about 30"). 285/75/16 is about 33". Add 10% to the displayed speed and you are done...
30 mph is 33
60 mph is 66
70 mph is 77....etc...etc
I think that is easy enough to remember...
Thermo
technical advisor
I ran my truck for a few years without recalibrating the speedo. Now, I was running a little bit bigger tire (315/75R16) and the truck performed fine even though the speedo was off by 16.7%. But, after putting in the new VSS gear (my truck is a 97), I noticed that my truck shifted better, at a more appropriate point, and my mileage actually went up (dropped 4 mpg due to the bigger tires, but came back 2 mpg after the speedo change). So, there are some other benefits to getting the speedo recalibrated. I know my case is more of an extreme situation, but it goes to show what the different sides are.
bsamc2000
bsamc2000
Ohio
Just a quick update....
I had the tires installed and they made a world of difference in the looks of the Expedition. I love it.
I called 3 different dealers in my area and they all told me that there is no way to change the calibration. And the 2 offroad shops around me want to sell me a $300 adjustable "box". Im throwing the BS flag on this one. I guess I will live with it for now until I buy a programmer.
bsamc2000
bsamc2000
Ohio
I plan on installing a pc in the Expedition with a gps as soon as I finish up a couple other small projects. I just need to find the right touch screen, remold my bezel and relocate the climate contols.
Thanks for all the replies and information.
Dcopp13
New jersey
I have 275/60R20 on my 2014 expy and i think i notice a different in the way it shifts. Especially on the highway trying to pass. Seems to be in too high a gear. My stock size was 255/60R20. I am also deciding which tuner to get. The dealer says they might be able to program it for $120 but it's not guaranteed to work.
