1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
Well here's a dumb thought! You've swapped out 5 or is it 6 starters, a ring gear, but never changed the starter solenoid on firewall. Sure sounds like the starter Bendix drive is trying to engage, but something's pulling it back. They don't fail often, but do. Buy a quality one, like Oem Ford or equivalent. I'd also pull the starter that's in there, and have an assistant crank engine with a socket/ratchet and fully inspect all teeth on ring gear. If one of your five chewed up the teeth, your looking at dressing the teeth with a sharp file, or another ring gear. As far as the starter falling out, wow! Their 3 bolts holding starter in. Whatever mechanic left all three bolts loose must have been high on something! Let us know your results.
