Strange chirping noise???
VexedEX
I've noticed recently when starting up my Expedition a chirping or squicky noice....once it warms up the chirping sound does go away. My first the was belts but they looked fine/ tension good.... What else could it be? I've never heard a noise like that before....
VexedEX
VexedEX
It's not really doing it anymore but I noticed it really only did it when it was colder out? Strange? I usually can pin point what a noise is but I couldn't figure it out. I'll let yall know if I ever come to figuring it out!
VexedEX
VexedEX
Could be the belt. Sometimes it will slip, causing a chirping noise. Check to see if the ribs look good.
Yes I did for sure... That was my first thought but look new? noticed noise while raining out a few minutes ago. So it's got to be the belt then, right? Bearing??? When I take it to shop I will have them check tension also to be certain. Thanks!
FordandPolaris
Saint Cloud, MN
if it were a bearing, I would think it would be chirping all the time. I would definitely say the belt is going out if it does it after a rain and in the cold, and they aren't too hard to replace if you have some time and a little patience. Pretty cheap too.
