Suspension Job Coming Up
Krellio23
Chicago
Greetings All-
This is actually my first post on this forum, but I have been lurking for quite some time. I spend most of my internet time over at LS1gto and decided its time to get active here as well.
I used the searched function and checked google as well to no avail.
Quickly-i've got a '97 XLT Expedition with 230,000 miles on an ALL STOCK suspension (swapped motor/trans/AWD a while back). Pretty incredible that the car still feels very connected. FWIW I do not believe this model has the air suspension.
I am going in to replace the rear trailing arms and also shocks on all 4 corners. What all else should I do while Im in there? Ideally, Id like to replace everything once while im in there and not have to do the labor two times. I am not looking for any lift or drop, just the cheapest options as far as bolt on replacement parts.
Can anyone give me an exact breakdown of what Ill want to replace while im in there?
Shocks, springs, trailing arms....what else? If anyone wants to throw some part numbers down it would be HUGELY appreciated as well.
Thanks in advance people :waytogo:
tonydiv
technical advisor
Middle River, MD
Get the energy suspension bushing kit for it. The bushings in the track bar are probably wasted. The kit has bushings for the upper and lower trailing arms, the track bar, front and rear sway bar links and mounts, and a few other pieces. It totally transforms the way the truck rides
K
Krellio23
Chicago
Thanks very much for the reply Tony. Bushing kit is on its way along with some other goodies. I cant imagine how badly deteriorated the bushings must be on this truck. Do you think a new track bar altogether may not be a bad idea?
I did a complete overhaul of the suspension on my GTO and it was the best mod ive done to the car (620hp street car) since Ive owned. Interested to see how this affects the truck.
Sterling Archer
Olean NY
My sway bar bushings on my 07 with 183k were freaking oval shaped when removed...Poly all around now just last week. Haven't been able to really test the difference because my new tires aren't on yet...but body role is definitely less noticeable on corners...
