Temp Spike On Highway Hill
zak99b5
Albany N.Y.
I just completed a 2500 mile road trip in my 2020 limited Max, first one in this truck I bought used last summer with 65k miles.
On the last leg of the way home, a 9-hour drive, I noticed that on a few long uphill sections of the highway (NYS Thruway, so nothing crazy), at 80 mph or so, the temp appeared above the idiot light. It was 23x*, and when I let off the throttle it dropped down and disappeared. Did not notice this on the drive out. We had 6 people plus luggage for a week, with a long Thule roof box on (19.4 mpg for the trip, btw). Outside temp was low 80s.
So I want replace the thermostat, seeing a couple threads about it on here. Apparently it was revised, and the updated part has a lower opening temp and black plastic on the end of the plunger. But I found conflicting part numbers.
Is the correct part RT1251 or RT1258?
And is there anything special I need to do to bleed the system when refilling the coolant?
TIA for any helip.
TheDoug
Mansfield, TX
I am not sure about part numbers as I upgraded my thermostat to a 170 degree one from spd. (And modified my tune to accommodate it)
As far as install I bought a gallon of new antifreeze and topped it off after install.
zak99b5
zak99b5
Albany N.Y.
Seems like the 1251 opens at 190*, and the 1258 opens at 180*.
1258 it is, I guess.
Or do I want a 170* tstat?
TheDoug
Mansfield, TX
Since I have a tune I opted to get the little bit cooler thermostat. I think the 180 is fine for stock application.
99WhiteC5Coupe
A thermostat that is rated lower than the OEM specification can cause lower fuel mileage due to slower full warm-up and also slower HVAC heat output in cold ambient temperatures.
If the engine is designed to operate in the 19x F range, a lower temperature thermostat (than OEM) will NOT cause the engine to run cooler. Once the thermostat opens at 170 F or 180 F - the engine will continue to get hotter (as designed).
zak99b5
zak99b5
Albany N.Y.
Yes, I understand that the thermostat doesn’t cool the engine; rather it guarantees a minimum temperature.
I ordered a 180* t stat. So cooling starts ten degrees lower than specified.
Unless my t stat was sticking, there’s zero reason for my coolant temps to be approaching 240* under the circumstances that it was. Truck was not overloaded (it should handle 6 people and luggage with ease), ambient was not very hot (under 85*), 80-83 mph isn’t all that fast, and the hills weren’t all that extreme—I didn’t need to floor it to maintain speed. Coolant is proper Ford coolant, and when cold the level is between min and max in the degas bottle.
My thinking with the 180* t stat is cooling will start from a slightly (5%) lower point, giving me a little more headroom.
zak99b5
zak99b5
Albany N.Y.
I forgot to add that I checked the trans temp when I saw the near-overheat happen, and the tranny was at 210*, which seems normal, and indicates to me that I wasn’t working the truck too hard.
chuck s
A larger radiator is really all that will lower the coolant temperature. I thought the Max came with HD Tow which at least used to include this -- if not it's fairly easy to fit one.
Don't be so sure "it should handle 6 people and luggage with ease." Not sure your cargo capacity but mine is a mere 1416 pounds which allows 236 pounds for each of the 6 passengers body weight and luggage. Plus that cargo thingy on the roof weighs something. A couple hundred pounds overweight shouldn't matter though.
-- Chuck
BMW2FORD
CT
Part number for the updated 180 degree T stat is BR3Z8575G. I’m using it and couldn’t be happier. Trans temps stay around 185-195 and coolant around 190-200 cruising on the highway. Occasionally, the temp does rise past 200f on hard long pulls on the highway and a bigger radiator will help that but about 99% of the time it’s in the 190-200 range. I did not see any loss in fuel mileage and had plenty of good interior heat all winter even when the temps were below 20 degrees compared to the stock 195F. If you cross reference this part or go to Ford.Parts.Com and check applications you’ll see it’s used in all Mustangs, Police / Utility type vehicles, Continentals and several other pretty common but hard use to be expected cars.
sixsix
Louisiana
Same thing mine was doing. Bought the updated OEM thermostat and swapped it out and she's all good now.
Dahammer
Try 1st to replace the engine coolant temp sensor located in the engine. That would be my 1st choice in replacing if it was me.
sixsix
Louisiana
Not when there is documented proof of the thermostats going bad and it being replaced by an updated part.
Dahammer
I'll agree with you on that. However, either the therm failed at 65,000 miles, the engine coolant temp sensor located in the engine failed, or both simultaneously. Therms nor sensors last forever. And If the therm died, it should have stayed open.
Therms open and close constantly based on temp of the engine.
And that goes back to the 1968 Ford Torino when ALL therms failed from ALL manufacturers of therms, and when they failed they stayed closed, and engine coolant boiled out of radiators.
sixsix
Louisiana
These are not the same type of thermostats that they had in 1968. Mine failed at 69k miles.
He also said his trans temp was also elevated, which is another sign of the failed thermostat. And pretty sure the thermostat opens when it gets hot, it doesn’t start out open when cold. It’s gets in a bind on its way open, not allowing it to fully open. Hence the redesign.
Dahammer
I got a 2022 Jeep GWS3 and drove to Philly last year in the summertime early evening. While on the NJ Turnpike, I open her up roughly 85mph, sometimes 90, throughout the trip. I used dash gauges to see the temps since the coolant spike to 240 degrees and stay constant, and the oil temp was hotter than the coolant. Eventually, the fans kick in, and you can hear the fans screaming, and then they drop temp coolant to 198 and the oil temp to about 215. If I got off the gas pedal, say to around 65-70 mph, everything started to cool down, and the fans didn't kick in.
Shortly after the trip, I brought her into the dealership for LOF and did mention what I saw and had some pics on my cell and showed him. They could not duplicate those temps.
This year all my cameras died. Brought her in for service under manufacturing warranty. She had 11,720 miles on her. 6 weeks of the fiasco with Jeep, numerous electrical ground faults, PCM mod failure, bad updates, and to top it off, Chrysler had all the wrong part numbers for this vehicle and had to repopulate the entire catalog with correct numbers.
Finally, Got her home and noticed that all gauges now reporting correct numbers, including the alternator charging rate.
Now that vehicle is in Lemon Law, and I got a New Expedition with fewer bells and fewer whistles, and am happy as a pig in mud.
Could this be a correlation? Jeep vs Ford? Not sure, But...
zak99b5
zak99b5
Albany N.Y.
New 180* t stat should be coming today. Next Wednesday I tow my smaller pop up camper up north for a trip. I’ll monitor the trans temp since I don’t have the numerical display of coolant temp above the bar.
zak99b5
zak99b5
Albany N.Y.
Did not get a chance to install the new t stat before the camping trip with the rain. Driving up to the campground, me and three middle schoolers in the car with gear and towing a 10’ box pop up trailer, I was watching the temps. It’s a 70 mile trip, so 1 1/2 hours.
Kept speed around 70-75. On hills after about an hour, got the 23x* degree warning a few times. Would cool back down quickly when I eased up on the throttle.
I also had the trans temp displayed for most of the trip, at it was running around 210-212* with a couple increases to 214* on longer hills.
On the way home, with fewer long uphill sections, I never got the temp warning. Tranny was at 208-210* with it hitting 212* briefly.
Im assuming the cts is in the head or just off it. Could be that the t stat is sticking or slow to open, so temps at the head rise while flow to/from the rad is impeded. The tranny temps were only 2* different on the two trips, using the same coolant as the engine. If ALL the coolant were 235*, I would expect the tranny temp would rise, being heated (rather than cooled) in the worst case, or at least tranny temps would not drop a couple degrees after climbing a hill as quickly as they did.
zak99b5
zak99b5
Albany N.Y.
Got the new t stat in today. Could not for the life of my find the petcock on the rad, so I just let all the coolant come out when I pulled the t stat.
Made sure to install the new with the jiggle valve at the top, which is how the original was. Original is actually a 195*, part no. HL3E-8575-AA. The copper plunger part does not move freely, and it can even get bound up on return and sit cocked.
Used the entire gallon of premix coolant I bought at the dealer. Drove it around to get it up to temp. Lower hose got warm. No leaks. I’ll recheck the level when it cools down.
Dahammer
When you go out and drive, turn on the heater and set temp on high. Open the windows also. By doing this, your getting rid of any air trap in the heater core and lines.
platinumexpy
These vehicles are notorious for transportation overheating when you make sudden brakes and speed ups. Specially when you are in highway traffic and you try to pass vehicles in front of you. I noticed it once before but the best way to remedy this is to be cool with the sudden breaking and gas on highway traffic.
