The worst has come....
DR3W
L.A. - IE/SoCal
Bought brand new spindles from fabtech last spring. About 3000 miles on them... But my bearings suddenly and randomly exploded completely ruining my brand new spindles. DEEP scraches all over it from the bearing being destroyed.
The 4 wheel parts store didn't even mention that my bearings should be matienced.
They were 100% fine so i didn't check or replace them. But the grease was all burnt. The parts store who installed them didn't even say a word or look at the condition of the bearings...
Gunna take the spindle to them tomorrow and see what i can do..
Any words of advice? I'll post pics asap. THanks :shrug::nono::shrug:
Thermo
technical advisor
DR3W, the spindle should have a race on it that can be replaced, restoring the spindle back to fairly new condition. If this is not the case, then you are looking at having a plating build up and machining to restore the surface back to where it should be. For the cost of this, odds are you are going to be better off getting new spindles. I wish the news was better, but that is the short of it.
DR3W
DR3W
L.A. - IE/SoCal
So there's no way to fix it... I could grind it down but dont want the bearings rolliong on that...
Any way to like fiill the grooves with anything? Like a weld then grind it down...
JUST4FUN
Admin
Moderator Administrator
Il
i have used speedy sleeves on pto shafts it seem to work good they might have an application fot the spindals
Thermo
technical advisor
DR3W, all you can do is to talk to a machine shop and see what they will say. If you can bring them in a spindle, that will help them give you a more accurate price assessment. Sure, welding is an option, but with hardened steel like you need for spindles, heating it up with welding is not necessarily a good idea.
DR3W
DR3W
L.A. - IE/SoCal
Thank god!!!! The scratches aren't on the critical part of the spindle! Pfew! The bearing rolls on smooth metal. Damn i lucked out there!!!
