Things that make you geniunely go hmmm....
tcwaltz
Niceville, FL
So, I tend to pride myself on paying attention when working on anything. Being an IT guy attention to detail is a must or one little unplugged cable in a server can create chaos when trying to troubleshoot. With that said, I'm lucky.
As you all know I replaced the motor in this 2000 EB. Everything has been good, even the el cheapo coil packs I used. Once in a while it will seem like it misses a little or idles a little rough, but hey, its florida, its hot, alcohol gas sucks so I'm not throwing codes so no biggie. Overall it runs good, getting around 10.5mpg in town with a bit of idling and 16 on the highway. Today I get out of the truck and I get a minor whiff of hot coolant. Pop the hood, the degas bottle is full, nothing on the ground. I had to double clamp the hose fitting going to the cross over on the intake (dumb design) so I know that isn't dripping. Look back at the line coming from the water pump up to the T lines at the firewall. I see a hose clamp not where it should be. Feel back to the heater core and yep, I totally forgot to put the hose clamp in place and tighten it up. I've put 1000 miles on this thing and at best its dripped a little. Maybe that water on the connectors was my rough idle (cops were really tight in the spark plug well so it can't have water inside). There is a T that feeds to the back so maybe the pressure was never enough to push the hose off. But I honestly can't believe that. When I released the coolant cap on the degas bottle it had pressure. Most likely there has been water on the ground but I thought it was condensation or it was leaking into the back of the block area and vaporizing since it was a drip.
All I can say, sometimes its better to be lucky than good.
ExplorerTom
Colorado
I had that line pop off while on the interstate. Just crossed the border from AR to OK. I got off on the first exit and reattached the hose and added around 4 gallons of coolant. When I got home to CO, I replaced the connector on the firewall with new one since the brittle plastic on the old connectors is what failed.
T
tcwaltz
Niceville, FL
Interesting...didn't realize those were replaceable. I just assumed it was part of the core. This was simply my error, but the fact it stayed in place amazes me.
stamp11127
Temple, Georgia
Well on the bright side - you didn't delete a partition then find out the backup failed......oops.
Flexpedition
midwest
Coolant overflow, degas bottle, antifreeze reservoir, radiator expansion tank, blow-down chamber, boilover box - I've heard that thing called a bunch of names, but never "detex". And you said it twice, so I'm intrigued.
T
tcwaltz
Niceville, FL
Degas is the correct term. Not sure where the hell I came up with detex. Apparently to many coolant fumes? :)
Damn Detex is the push alarm on a fire door. LOL....degas bottle...yeah that.
