Third row seats won't move
SMWMUSTANG
Germantown, TN
greetings,
Out of the blue my third row seats quit working. I searched for some threads but did not come up with anything. One day they worked and then the next nothing.
I checked the fuses best I could?
Any guidance or direction?
Thanks
Shawn
B
bedrck46
Have attached prints for your seats Could be a fuse Check with a meter or could be a relay
B
bedrck46
Things to check
Fuse(s).
Circuitry.
Seat control switch(es).
Power seat motor.
Power seat relay.
Power seat motor drive cable.
S
SMWMUSTANG
Germantown, TN
I looked up the fuse locations at one point but lost the print out. Anyone have the locations of those.
Also, will the power switch in the rear just pop out of the panel?
B
bedrck46
you can download a copy of the owners manual which will show the fuse locations.
owner.ford.com
B
bedrck46
Prints 151-31 shows the location of #2 relay box
B
bedrck46
let me know if you need any other prints The relays may not be all that easy to get to Not sure as I have a different year than yours but you can swap the relays to see if they are the problem That is if only one side is bad
B
bedrck46
when you do find the cure to the problem kindly leave a update
Guyto
Montreal Canada
I have the same problem with my 2003 expedition, I am also thinking relay, but leaning more towards ground. I already verified the ground and it seams fine, cleaned it and tightened it. Wouldn't it be a pretty good coincidence to have both relay fail at the same time? You would think, in the case of a relay that they would fail one at a time. I will let you know how it turns out.
Thanks
B
bedrck46
Guyto Check the fuses with a meter Fuse#5 is power feed for both relays.
#104 and #117 are for the relay contacts 1 for each relay
Check the prints attached to this thread and if you need any other prints or information let me know
Guyto
Montreal Canada
Third row seat don't work
Hi,
This is where I'm at:
I checked the relays and they are fine, but I just found out that both seats will go down from the second row switches, but the won't go back up, also nothing happens from the switches in the rear.
So it means ground is good so are the fuses.
Now looking at the schematics 120-04 and 120-05, I think I'm looking at the rear switch being defective, what do you think?
Guyto
Montreal Canada
Hi,
Newport News, VA
Didn't read all the posts...were the switches checked and seat motors?
B
bedrck46
Look at print 120-05 at each switch you will see a letter A, B etc. Check each of those with the # 2 or 8 and see if you have power
Guyto
Montreal Canada
Finally Found It!
It was the second row seat switches that were defective, I just put in solid jumpers and will only be using the rear switches from now on, I will look later to buy new switches.
You would not think that two switches would go at the same time, that's why it takes you off course in the troubleshooting.
Thanks everyone for your help and diagrams.
B
bedrck46
That is why it is always best to start at Point A and work toward Point Z and check everything in-between sometimes is more time consuming but that way everything is checked
S
SMWMUSTANG
Germantown, TN
I have checked the 3 fuses and they are all good. My next step is to check the rear switch and then the relays. I don't think both motors would go out at the same time but it is possible.
Anyone know how to get the rear switch out. It looks like the whole panel pops into the back but it is very tight and I did not want to break it. Also, if I have to check the relays, how do you get the interior piece out with the seats in the way?
Shawn
B
bedrck46
when you finally get the switches out look at print 120-05 Check the left and right REAR switch between pins 4 and 8 and pins 4 and 2 You should have 12 volts with key in the on position.
If you have 12 volts then go across pins 3 and 7 on each Rear switch Operate the switch depending on which direction you press you should see either + or - 12 volts
Post the results
Then you want to do the same for the front left and right switches
Post the results
B
bedrck46
The procedure to remove the switch isn't all that hard but it does involve removing panels If you send me a PM with your e-mail addy I will send them to you There are 7 pages but mostly pictures
