Tortion bar upgrades.
markanthony
Bountiful
I have done allot of research. I am going to be install 7700 tortions on my 99 expy with new shocks. I am also going to be installing a rear coil spacer to level out with new shocks. I am also ordering a new set of them traction bars on the rear axle, with poly bushings.
I am also looking into replacing the bushings on the sway bars, or just upgrade them completely.
Question. Are there any other "little" things that need to be replaced? Brake lines longer, etc.
Thermo
technical advisor
Suspension wise, you should be good. Since you are going to be into the suspension like you are, it may be a good time to look at the ball joints and what not. Because of installing the 7700 bars, you may want to also look at an alignment once you are done since the front end camber is going to be off by a little bit since the truck will be sitting a little higher.
markanthony
markanthony
Bountiful
I figured on a alignment afterwords. It's those little odd things that I may not be thinking about.
