total electrical power loss for 5 minutes
John Dycus
So last night I pulled my 2009 Expedition Limited 2wd into my driveway, put it in park and turned it off.
I noticed that the headlights went off and the interior lights did not come on when I killed the engine. Everything was dead as if I had removed the battery. No lights, ignition, horn... nothing. I popped the hood and the battery terminals were corroded pretty bad. Up until this happened I have not had any charging issues. I was about to get my battery cleaning supplies to clean the terminals when everything came back on as if nothing had happened. Started right up without hesitation. I had not touched anything, not even the battery. Didn't act like it was even a low battery.
Security system?
A dead short, why would it have started again without doing or touching anything?
Most of the time it runs great but last year my AC suddenly went out without any warning. It was working great and then nothing. At the same time all of the power outlets stopped working except the one in the very rear.
Also, sometimes when I pull out it will not shift out of low gear unless I stop, turn it off and back on then start again and it shifts fine. Also there are times when it shifts you can feel it "jerk" like it doesn't know if to shift up or down when you are just maintaining a steady speed. If I pull out with a bit fast like accelerating for the freeway it is always smooth. Never feel the trans slipping at all.
The AC compressor is good and the system is fully charged.
All fuses are good.
stamp11127
Temple, Georgia
Power loss: clean the connections and apply a barrier to the exposed connections. If you want to keep any presets you will need to supply power through the cig lighter.
Your battery should be maintenence free for that year. The corrosion you have shouldn't be there. Does the current battery have caps to add distilled water?
Fix this then we'll attack the other issues. The electrical system needs to be in good shape before checking electrical issues.
J
John Dycus
Absolutely cleaning battery terminals today. It's not a maintenance free battery. I bought this about 2 years ago. I will also put a new battery in it today.
1955moose
Along with the positive cable, be sure the ground, both from battery, and frame connections are clean and tight. Has any electrical, or repair work been done recently? Last year or so? Sounds like you've got bad corrosion in cables, or a shorted cell in battery. These vehicles are totally dependent on a strong 12 volts at all times.
J
John Dycus
Thanks for both replies. Replaced the battery with the factory recommend one. Also the positive battery terminal end was broken.... thin metal end. Replaced it also. Both battery cables and battery are good to go
J
John Dycus
Electrical seems ok now. Shifting better so far but haven't driven it to far.
Wondering about the AC & power outlets
1955moose
So, did they test the old battery to see if it was bad?
J
John Dycus
I didn't have them test it. I just bought a new one. Transmission shifting seemed better for a day but now it is back to what it was doing
Boose
2017 Platinum EL
NJ
I had a similar issue with my Mustang years ago... The battery cables appeared fine however the corrosion was all internal under the insulation. it would intermittently handle some voltage. As soon as any kind of amperage draw was placed on the system the whole thing would shut down. I had to cut back insulation on the cable to find it.
1955moose
That was what I was thinking. We've been getting a lot of internal cable problems. The severe cold sure isn't helping.
J
John Dycus
I'll be replacing the cables next.
I'm still really curious about why I lost power to all of the power outlets except the one by the liftgate. Pain at the same time the air conditioning stopped working. The compressor is good it's fully charged none of the fuses are blown and I've also checked that power is getting to the fuses and through them
1955moose
How can you bypass cables teach? Is their a test of sorts? An ohmmeter test maybe. Never had an internal cable issue.
