Deadman
Exactly. There's many Platinum's running around without a locker, and tow pack.The Platinum only has the locker if you select the HD Tow Package with 3:73 rear end.
*Waves*Exactly. There's many Platinum's running around without a locker, and tow pack.
Exactly, the 2007-2014 Expeditions with the Control Trac 4WD system have 4 wheel traction control with an off-road mode according to the manual. This applies brake pressure to wheels that are slipping via brake application and sends power to a traction wheel. They did away with the LSD in 2007 because the two would fight and in testing they found the 4 wheel traction control to be more effective than a single lsd. The traction control on mine is a totally different animal if in 2WD or 4WD. According to the manual off road mode is automatically engaged in the 4L selection which alters the braking bias.With all the electronic crap on these newer vehicles, a locker can barely do its job, because the brakes often slam on before the locker can even lock up.
I would have thought a Locker locks it and runs that way … not kicks in when needed?With all the electronic crap on these newer vehicles, a locker can barely do its job, because the brakes often slam on before the locker can even lock up.
So, I think I'm starting to understand how my 2014EL works. If I have it in AWD power will be delivered to front and rear wheels. If rear starts to slip then the computer will send more power to front wheels to try to keep them turning at same rate. I have a LSD in the rear so if one rear wheel starts to slip the computer will apply brakes to that wheel and the LSD will give more power to the other rear wheel. If I didn't have LSD in rear and one wheel started to slip then it would spin and I'd lose all traction in the rear. If I had a locker in the rear both rear wheels would turn at same speed and if one started to slip the other one would keep driving. Do I have this right? Oh .. and LSD's kind of stop working after 100K miles or so.
Generally if a locker is activate the traction control is turned off and if the locker is activated the rear wheels are turning at the SAME rate and traction control will see they are turning at the same rate and not activate any braking there anyway.
If we are talking LSD...maybe. Not sure how they are on the newer ford. If they are electronic and tied to the TCS then the TCS might activate the LSD rather than apply brakes.
I believe the traction control defaults to ON every time its started, so I rarely think to shut it off ahead of time. So then the traction control tries to kick in as or before the locker tries to kick in, so I'm not sure which one kicks in first. Old school with no traction control, then the locker just did the work and you could actually spin your way thru stuff if needed.
do tellA lot of mis-information or at the least mis-understanding here of what LSD, locking differentials, transfer cases, and how they all work!!!
I like all the confusion resulting from the assumption that the rear differentials installed on older Expeditions are in any way related to the eLSD with locking mode installed in the 3.73 rear found on 4th gen Expeditions.A lot of mis-information or at the least mis-understanding here of what LSD, locking differentials, transfer cases, and how they all work!!!
The rear differential in question is an electronically controlled limited slip differential with locking mode. The electronics control a hydraulically actuated clutch pack which divides the torque between the rear axle driveshafts. This is very, very different from a traditional locking differential (which has two modes: open and locked). It is also very different than a limited slip differential (LSD) which mechanically limits on the difference in rotational speed between the axle driveshafts (and which has the speed differential is defined by the physical design of the components of the differential). It is also very, very different from an electronic limited slip differential (or pseudo-LSD) which uses the ABS components and software to apply a braking force to a slipping wheel.do tell
wow, nice even I can understand that!!The rear differential in question is an electronically controlled limited slip differential with locking mode. The electronics control a hydraulically actuated clutch pack which divides the torque between the rear axle driveshafts. This is very, very different from a traditional locking differential (which has two modes: open and locked). It is also very different than a limited slip differential (LSD) which mechanically limits on the difference in rotational speed between the axle driveshafts (and which has the speed differential is defined by the physical design of the components of the differential). It is also very, very different from an electronic limited slip differential (or pseudo-LSD) which uses the ABS components and software to apply a braking force to a slipping wheel.
A rear differential with an electronically controlled, hydraulically actuated clutch pack with locking mode (like that in the 3.73 rear axle installed on 4th generation Expeditions) is designed to give one the best of all possible worlds. Like a locking differential, you can force the axle drive shafts to rotate at the same speed no matter how much traction each tire has. Like a traditional LSD, you can the rotational speed differential between the two rear drive shafts. And like a pseudo-LSD, you can respond to vehicle sensor data and vary the torque between the axle drive shafts. But unlike a locking differential, you can allow some (but not infinite) speed differential between the two axle driveshafts. And unlike an LSD, you can choose whatever speed differential you want. And unlike a pseudo-LSD, you can actually lock the rear differential.
So, in the 4th Gen Expedition, how does the rear differential actually operate? Well, that's what the drive modes are telling the system to prioritize. Set it in 4A, and it's going to assume you're driving down a highway and it's going to act like a lot like a traditional LSD or pseudo LSD. Choose "snow" and it'll likely do really cute things, like act like a locking LSD when you're stopped but also watch your speed and yaw sensor* to keep from putting you in the ditch....
The downsides are cost, complexity, and heat build up in limited slip mode.
*Note that the center transfer case in these fords is also a hyrdaulic clutch pack. So "icy/slippery road" mode is also going to be varying the center transfer case clutch pack to keep you from spinning round and round should you hit a patch of black ice, which was the bane of 4H 4x4 systems.)
No assumption they are the same, I was referring the old mechanical style limited slip found in the gen 2 Expedition and why they did away with it in favor of software/ tc. They now use an electric lsd that doesn’t try and fight the traction control systems. Also a much better solution than the old mechanical style that wears out.
