Towing Capacity
Matthew Pullen
Background, looking at purchasing a 2016 Ford Expedition for towing a family RV. Need to know how much the Expedition with the twin turbo ecoboost with 3.31 gears can tow. What is the towing capacity for this vehicle?
Eagle 71
Nebraska
https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/Ford_Linc_16RVTTgde_r4_Jul27.pdf
Hi Matthew, welcome to the forum!
Pg. 22 of the attached link should help. Depends if your Expy is a 4x2 or 4x4, and if it is equipped with the optional trailer HD Towing Pkg.
To determine the latter, if your Expy you're interested in has a factory-installed 7-pin electrical towing connector, a separate tranny cooler in front of the radiator, and a factory electric brake control for your trailer below the dash, it probably came with the HD towing package. With the VIN though, your Ford dealer should be able to confirm all of this.
coolzzy
Idaho
Do yourself a future favor and DON'T BUY an expedition with 3.31 gears regardless of trailer size. When evaluating a full size vehicle for tow purposes, even occasional, always always always get the lowest offered factory gears, in this case you'll want 3.73 and HD tow package (which includes both 4 and 7pin plugs, factory integrated brake controller, and larger oil and transmission radiators). Bcsn it be done with 3.31,sure, but no doubt the 3.73 does it better and will stop you from upgrading out of it earlier than planned. Don't be fooled by mpg difference either, the 3.73 geared trucks get within 1mpg or less of the taller geared 3.31 and you'll never say you wish you had less towing power.
HD tow package expeditions with 3.73 gears are rated to tow 9300 pounds max, but you'd want to stick to 6-8k pound range for safety margin.
JasonH
Houston, TX
I pull a 7000lb (wet), 31 ft trailer with my 2017 Expedition using WDH. Plenty of power for hills and such. Gets a bit squirrely in the wind, but this could be tires too. I usually drive between 55 and 65 depending on wind. Any higher than 65 and fuel economy plummets. I get between 8 and 10 mpg at these speeds. The payload limits the vehicle to this trailer weight, as there is only ~1650 of payload before the travel trailer gets hitched, and the hitch weight consumes most of it. The 9K+ tow is a pipe dream if you have any passengers or a high cd. Maybe if it's a load of bricks you could get near it, but not with a long travel trailer.
rollinstone
Seattle
My TT weighs in at 3500 for trips. 2014 Expy LTD, 3.73 gearing has full HD tow pkg. Avg a solid 12 mpg even pulling in NW mountains. I also installed a WDH with built in antisway.
Dr0idattack
Bentonville, AR
Which WDH do you use?
JasonH
Houston, TX
Here are the numbers from my last trip to the scale. I have since added more weight on the front axle, but I think the numbers were close to where they needed to be. I may stop at the scale again since we're towing this weekend.IMG_20190613_182947972.jpg
martinbrown89
united states
I am looking for a trailer for car towing service basically we are running a towing company manhattan towing service for that purpose we need a towing trailer which must be reliable and durable. any recommendation, please.
Flexpedition
midwest
You'd never catch me towing a car trailer in Manhattan.
Manhattan Kansas, yes, but not NY.
Opinions will vary, but for dedicated car hauling, I'd look for:
* Dovetail. You might even consider a split dove tail for faster/easier tie downs.
* Aluminum. I've had enough steel trailers & will never own another one.
* 18 to 20 ft. Bigger isn't always better, especially driving in NYC. 10K GVW.
* Extruded aluminum floor rather than wood. With integrated D-rings.
* Rubber Torsion axles. 3500# each. Better riding trailer versus spring.
* Electric winch up front, especially if towing disabled cars.
* Removable fenders, at minimum on the drivers side.
browncow
