Towing Question
seansolo
Fresno, CA
Hey guys,
I have a 1999 5.4 4x4 Eddie Bauer with Tow package and I'm planning a long distance move. I will be towing a 3300 lb Jeep Cherokee. I don't want to have to use the tow dolly system and was looking at UHaul's Car Carrier system. The site says the carrier is 2100 lbs and Jeep weighs 3300 lbs, for a combined 5400 lbs. What do you guys think?? Also, how do you tell if the factory Tow Package and Hitch is a load leveling set up?? Any input would be much apprectiated. Thanks
joecrotch
santa fe NM
It would be easy to tell if there is a load leveler on the hitch. it is 2 Large bars that atach with chains to the trailer and chains hang off bottom of truck. I have never seen a load leveler come standard on a vehicle its usually something that is bought after market.
As for your towing, I used the full size car carrier with a BMW 3 series on it. I towed that all the way from Phoenix to Santa Fe NM. No problems at all.
S
seansolo
Fresno, CA
Oh ok, very cool, thanks for the information. It looks like a pretty heavy duty hitch on the rig, and I know it is what came stock. I am thinking that I should be able to tow quite a bit with it and 5400 lbs doesn't sound like that heavy compared to some trailers I've seen being towed by Expeditions. Thanks again
98EBEXPY
should do it I've towed heavier just take it slow
sgtowing
Supporting Members
Valrico, Fl
You'll be fine and you don't have to worry about stopping cause u-haul trailers have self actuating brakes. The harder you stomp on the brake, the harder they apply.
Sent from my DROID BIONIC using Tapatalk
Rod240sx
NJ
^^ they sure do... I did alot of hauling with a Uhaul trailer few years back by and in most cases, the trailer would slow the truck down ha! You can actually feel the trailer pulling on the truck
LameSuburbanDad
rockwood, MI
their right, 5400lbs is a little over half of the manufacture recommended weight... these transmissions are used in not only the larger diesel Excursions but also in some of Ford's larger Fleet type vehicles...
It is extremely strong, and durable. It can be made a TON better with a $40 shift kit
You shouldn't struggle to get that jeep towed.
expect to get around 9-12 Mpg avg.
Jay87LX
Cleveland oh
Link to that shift kit?
LameSuburbanDad
rockwood, MI
http://www.transmissioncenter.net/Shift_Kits.htm
scroll down to number 20. they list it for $45
I just had a transmission redone (there is an ongoing thread in the transmission section) and the trans guy added a "mild" shift kit to the trans. it firms up 1-2 and makes it very short and almost unnoticable under light accel.
the rest of the shifts are noticeably quicker without making it tough to drive
if you look in the thread I posted a picture of the receipt, I don't say bill because I didn't pay anything, it has a warranty.
