TPMS another question
khpony
SW Colorado
My other thread didn't help much. A simple question: does the spare need to have a tpms sensor for the system to work correctly?
Bedrck47
Elizebethtown, PA
if your other thread didn't help much what makes you think this one will
the same people read the threads so you most likely will get the same replies
K
khpony
SW Colorado
Actually my question was part of the other thread but I never received an answer to it. I thought it might be prudent to ask this question in a separate thread. I had good responses to the other thread just not an answer to this.
Thanks!
K
khpony
SW Colorado
Its been on since I bought it a month ago. It has 2 brand of tires on it. I bought 4 new continentals today for it but want to troubleshoot the tpms system em before I pay to have them mounted/balanced. I have 4 new sensors but they lack programming. I've looked at buying the ford programmer on amazon for $35 but will still like to know if the spare needs a sensor.
Thanks!
Bedrck47
Elizebethtown, PA
that I don't know the answer to but you will need to have the new sensors programed
I would give a ford dealer a call and ask but let him know that you also may want to buy a sensor because one is missing tell a little lie
Bedrck47
Elizebethtown, PA
Principles of Operation
The tire pressure monitoring system (TPMS) has the ability to monitor the air pressure of all five tires. The tire-mounted pressure sensors transmit signals to the TPMS module by using the valve stem as an antenna. These transmissions are sent approximately every 60 seconds when the vehicle speed exceeds 32 km/h (20 mph). The TPMS module compares each tire pressure sensor transmission against low and high pressure limits. If the TPMS module determines that the tire pressure has exceeded the limit, the TPMS module communicates on the SCP network to the vehicle message center, which then displays a warning message. The system is not affected by wheel and tire rotation.
Vehicle Message Center TPMS Messages
The vehicle message center sometimes displays messages that cannot be resolved by the customer. Treat these messages as TPMS system faults that must be serviced. Refer to the symptom chart for the following messages:
Warning—Tire Very Low
Displayed when one or more tires have very low pressure. When this warning message is displayed, a warning chime will sound reminding you to stop the vehicle as soon as safely possible and check the tires for correct pressure, leaks and damage.
Check Tire Pressure
Displayed when any of the tire pressures are high or low.
Check Spare Tire Pressure
Displayed when the spare tire pressure is high or low.
Tire Pressure Sensor Fault
Displayed when a tire pressure sensor is malfunctioning.
If the customer requests that the TPMS be turned off, it can be done by configuring the message center through the instrument cluster (IC), using the scan tool.
Newport News, VA
theres a way to reset if I remember without a programmer...think u needed a magnet though
K
khpony
SW Colorado
That's what I needed to know. My spare wheel doesn't have a sensor on it. When I get my new tires mounted tomorrow I'll have the best used one moved to the spare and have a sensor installed on it.
THANKS DetroitDarin!!
Bedrck47
Elizebethtown, PA
the information I sent you earlier today mentioned about the spare tire warning I had hoped you would have caught on to that
DetroitDarin
That's how you do it - if you need to take a TPMS out of a regular wheel and install on the spare wheel, just do that thing. Or buy a new sensor - have them reset; should be good to hook.
Let us know how it works out.
K
khpony
SW Colorado
Actually I caught the note on the spare tire but I only have a spare rim w/o a tpms sensor. If I remember correctly on an 08 Limited I used to have the spare didn't have a tpms sensor.
Bedrck47
Elizebethtown, PA
the following DTC (codes) apply to the 2003 thru 2009 TPMS could not check for 2010 and newer
B2885 MAY NOT BE SUPPORTED FOR ALL MODEL YEARS
B2868 Left Front Tire Pressure Sensor Malfunction
B2869 Right Front Tire Pressure Sensor Malfunction
B2870 Right Rear Tire Pressure Sensor Malfunction
B2871 Left Rear Tire Pressure Sensor Malfunction
B2872 Tire Pressure Sensor Malfunction
B2885 Spare Tire Pressure Sensor Malfunction
