transmission lines leaking
48dually
NY
I have a 1999 ford expedition 5.4l and the cooler lines right above the tie rod are leaking. does anyone know of a diagram so I can get the parts numbers? one of the brackets broke causing the lines to rub on the tire rod as you turn back and forth. tried to fix it but thought best option was to buy new lines. any advice would be greatly appreciated. Thanks, Jamison
