transmission swap im lost
Discussion in 'Transmission & Drive train' started by tossen12, Jan 11, 2020.
  1. Atman246
    Atman246 Full Access Members
    58
    73
    38
    Feb 11, 2017
    Ontario,Canada
    It's been a long time since I've worked on one of those,but that sounds electrical to me. You'll need a good shop to diagnose that issue. An internal speed sensor dropping out or a solenoid not avtivating properly. Could even be a pcm reprogram for an updated transmission. At least in my opinion it's not a burnt clutch pack issue. Good luck.
  2. tossen12
    tossen12 Member
    60
    Jan 11, 2020
    88130
    Thank you all for the information . It looks like it's back to the shop . Thanks again.
  3. TobyU
    TobyU Full Access Members
    1,865
    646
    Apr 5, 2013
    Ohio
    It also sounds electrical to me but it could also be in the MLPS sensor.
    I had one go out on a 94 AOD-E model which was actually installed in a 92 car and it had some weird jumping into neutral and not shifting into 2nd issues. Replace the sensor and the new upgraded pigtail that the switch pigtale that they switched the terminals in and it was fine after that.
    Find someone that knows someone who works at a transmission shop or has the expensive diagnostic Hardware to watch what the transmission is doing as it's being Road tested. You have to have a friend because otherwise a shop will just want to tell you it needs a rebuild.
  4. CaptOchs
    CaptOchs Full Access Members
    40
    105
    28
    Jan 27, 2018
    Rochester NY
    I'm guessing programming. I was in a similar situation with a Charger. The tranny went bad so I got a junk yard one installed. When I went to take it home I couldn't get past 45mph. I took it back and the tcm needed to be reprogrammed.
    If the new transmission is indeed defective, it should have some kind of warranty. Mine was 6 months. More than enough time to determine if there's any problems with it.
  5. TobyU
    1,865
    646
    Apr 5, 2013
    Ohio
    I don't think an 05 really has any programming. It may very well adapt to your driving a little bit but not nearly as sophisticated as the newer ones.
    Short of resetting the computer codes and taking the battery cable off for a few minutes I don't think anything else would affect it.
  6. tossen12
    tossen12 Member
    60
    Jan 11, 2020
    88130
    Thank you all for the wealth of information . As soon as I get the chance to work on it again , I will update . Thanks again
  7. Alex Lopez
    Alex Lopez Member
    Jul 10, 2019
    78418
    if you drive with the overdrive off does it have the same symptoms? perhaps your replacement tranny has the "lost overdrive" problem...
  8. tossen12
    tossen12 Member
    60
    Jan 11, 2020
    88130
    I haven't tried it with you he OD off yet . I will try it as soon as I can . I work 10 to 12 hour days 6 day weeks . Limited to one . Lol
  9. riphip
    riphip Full Access Members
    67
    52
    Nov 6, 2018
    Memphis, TN.
    My old job, now retired thank God!!!
  10. Frank Swygert
    Frank Swygert Member
    58
    16
    Feb 20, 2019
    Gilbert, SC
    I had a similar problem, but mine wouldn't go into 3rd at all. I was driving along and it just dropped down to 2nd and wouldn't shift any more. It's an 05 with 105K on it now, 99K at the time (last August). I had towed a camper about 150 miles to the beach and been there a week -- the night before we were coming home the trans acted up! Stored camper and drove it home in 2nd gear, just didn't run over 3000 rpm (right at 50 mph) all the way home. Turned a 2 hour trip into 3, but got home safely. Turned out to be a snap ring inside the trans that let go, a common occurrence according to the shop I took it to. They installed a lot of upgraded parts, including a spiral stainless ring in place of the iron snap ring. Seems like it was about $3500 total for the rebuilt trans, dropped truck off and picked it up three days later. They didn't rebuild mine, but installed one they already had rebuilt... saves time, and it's a common enough trans to keep a couple on hand and rebuild when shop is slow. Gets customers out faster.
Share This Page
