Trasmission oil temperature
gural
Poland / Europe
Hi
I tried to look up in the interet/ forums/ youtube
That is the proper max oil temperature in transsmision (2019)
I see that in can be up to 230 F
and during 220 F there is a termostat that opens to cool a transmission a bit
Usually i do not cross 210 F (but i try not to go too fast - up to 75)
Sorry for quesiton but in Europe we got diffrent speed limits (90 miles/h) and in 2weeks i got to Spain (temperature like in Texas)
And I thinking about buying and installing additional cooler (something like this - https://shop.advanceautoparts.com/find/ford-expedition-oe-transmission-cooler)
What do You think??
Be greatfull for Your opinions
JasonH
Houston, TX
I think you're fine with the existing cooler. When going up steep grades, use the lower gears and slow down. The fluid is designed for temps in the 230+ range. Also, be sure you're using a good quality Mercon ULV fluid.
G
gural
Poland / Europe
I m after the change of transsmission oil - accoring to FORD - ULV
And becouse I am a old user of ATF I change in every 50 k miles - in order to have longer life
Thx for information
G
gural
Poland / Europe
Further more
Accoring to
I found that the normal operating temperatur on long trips (or during the towning) is between 200-225 F
For all three ambient temperature conditions the final engine oil temperature for the US06 is around 100° C to 110° C.
Due to have better fuel economy and smoother change gears the ULV oil is working the best between tose temperatures
And ULV is designed to reach even 290 F without any problems
mr_dave
MN
From an actual transmission engineer:
You can run the trans as high as 220F all day long with NO ill effects. You can go as high as 250F for no more than a half hour at a time.
Staff online
tifanydire
