trying to install HID low beams on my 2018 expedition
RhinoQuartz
USA/CAN
Your “literally linked” article o my addresses the following
Two points in particular remain subject to interpretation in the FMVSS 108 standard. The first relates to LED testing for signal and marking lights such as LED tail lamps or LED lamps on the outside of a vehicle's rear-view mirror. The second is specific to photometric degradation and the calculation of Effective Projected Luminous Lens Area (EPLLA).
Has nothing to do with low beam headlights. You have a thick skull and should read more. You are also super annoying, like a gnat at a bbq... you’re arguments are invalid to me and I choose to not listen to the nonsense that spills from your mouth. Bye bye :mfr_closed1:
From your quote above "... which we call Street Legal".
Not DOT or some other legislative body, but the company selling the product. Who have a motive to sell it, to earn money.
You still don't have a set of federally legal PnPs to show.
dlcorbett
Air Force
tx
Those are illegal to put in the headlights... just ask @RhinoQuartz he will tell you
I wouldnt need illegal bulbs if ford made their factory leds standard or did better with the halogens(they SUCK). And on that note...ill let ford handle that when i give em back the truck lol
RhinoQuartz
USA/CAN
LED upgrades do cost more although halogens are actually better, watt for watt. They throw light further and aren't as disturbing to oncoming drivers - halogens are usually warmer too, even if white, and puts less strain on the eyes of oncoming drivers. France even had law that required all headlights to be yellow for this exact reason.
G213
Los Angeles
:emotions33: sooooo anyway.....could one retrofit the factory LED setup after the fact? Just curious. I'm guessing it would be expensive. (I know the OP just bought his truck, I'm just curious for sake of education)
RhinoQuartz
USA/CAN
Well, theoretically yeah. You can buy the parts online. Probably need to check the service manual for the correct part numbers and installation procedure. Forscan for reprogramming if needed.
16plati
VA
Yeah Thts illegal
1955moose
I've got a dumb question. Aren't the newest Expeditions equipped with the optional running/fog lights like my 19 year old Eddie Bauer? I adjusted my stock setting up about 15-20 feet above stock, on the fog lights. I get a great projection just slightly less than my high beams. I rarely get flashed, and I'm running stock Ford bulbs in all 4. Shame in this day and age, they can't build a stock headlight, that's barely better than the dim 6 volt setup I drove with back in the day. For $75k, you think they could put on a decent set of headlights.
16plati
VA
Oh good job trolling. Explain the illegality of it.
Taking the manufacturers product, cutting it open and putting something else that wasn’t tested specifically with that product into it, trying to reseal it, and putting it back on there. Sounds way more “illegal” than just tossing in a set of quality plug n play LEDs...
But you obviously know wayyyy more than anyone else here about vehicular optics
RhinoQuartz
USA/CAN
.... What? Do you read what you type?
Retrofitting the correct housings is actually the correct thing to do. It ain't cheap, and it ain't easy. But visibility and light containment will better for everyone involved.
Did your ego seriously get that hurt because I pointed out PnPs aren't really that safe and that the ones you bought and use aren't certified as road legal by the DOT?
dlcorbett
Air Force
tx
The new trucks do have running fog lights and its best to use them in unison with the headlights. Only thing i dnt like is you cant run the fog lights on the auto setting together, its one or the other.
For 75k, the truck comes with the led setup and noone complains about that setup, the issue is, their optional and only on the higher trims when it should be std this day and age. Also, what hurts the halogen performance is the design of the projector housing, which instead of focusing the light makes a cutoff pt too low to be useful in a vehicle the size of the expy.
Lastly, you cant retrofit the led lenses and headlight to the ones without, the fitment for the hosuings are different and wont allow the swap. This has been talked about alot in the beginning of the 4th gen days
G213
Los Angeles
Really? So you have to turn the headlamp control out of auto-lamp and into "low beam on" to use your fogs? That's annoying. I know on my '16 I can use the fog lights in auto-lamp mode. There's probably a forscan tweak you could do to allow you to run fog lights in auto-lamp mode.
1955moose
That just sounds wrong. Headlights should just be right, right off the showroom no matter what trim level. I had the #6014 sealed beam glass headlights on my old 1970 Datsun 240Z. They were fantastic, low beam was sufficient for 70 percent of my driving. It lit up the skyway. I was impressed from day 1. It's sad, with all this high tech crap 49 years later, they can't even make a headlight as bright as my old car. Every day it's something new we have to change, or adjust down to. What's next? 60 year old eyes need better, not worse headlights. Time to call your old eyes congressman and see how he'd like it driving himself home, instead of his young heavily armed driver, who can see like a raccoon!
dlcorbett
Air Force
tx
In auto lamp mode, the truck cntls when to turn the fl on, and it only does during very extreme low light conditions.
RhinoQuartz
USA/CAN
Which is the point of not having them on with low beams. Having the fog lights on in normal lighting conditions doesn't really help with seeing further, only a bit more peripheral vision, and can actually make it more difficult to see into the distance as your eyes aren't accustomed to the dark as well because your foreground is so lit up.
Additionally, depending on your jurisdiction, there may be a limit to how many lights you can have going at one time.
1955moose
See, that's why I raised my fog lights up quite a bit. Mine too were just a wider path, with no height. I have a big wall behind my place. About the size and height of a handball court. I raised each up about 2 feet on the wall, parked back about 10-12 feet. It made a world of world of difference on my Suv. I had to do a little tweaking over the next few days, but got it to where it works. Does the Gen 4 lights have an adjustment like the early ones do?
old codger
Jefferson City
16Plati, when you used the leds did you find an easy way to adjust them. With these newer headlights adjusting most leds are a pain in the xxs. Most leds are adjusted by rotating the collar which is a pain because the adjustment requires removing the complete assembly, possibly numerous times to get desired light cut off.
16plati
VA
16Plati, when you used did you find an easy way to adjust them. With these newer headlights adjusting most leds are a pain in the xxs. Most leds are adjusted by rotating the collar which is a pain because the adjustment requires removing the complete assembly, possibly numerous times to get desired light cut off.
Hey @old codger on my 16 there is an adjustment screw accessible just by opening the hood. Set it up 25’ away from a white wall in garage and measure the height from level ground to 3”. Turn your lights on and adjust each bulbs left side cutoff until both are level to the 3” mark. Should look like this when done CA671816-3FB5-45C8-BEE4-38BF2B9F4E4F.jpeg
