Turn signal only left
NC
Ok, I have a 2008 expedition limited, and its having an issue with the turn signal. When it's in the neutral or left position it blinks left, pushing it up to the right cancels the signal out. I suspected that the issue may be within the switch itself, however, when I disconnected the switch entirely, the vehicle blinker turned on (left). Is there a relay I'm missing? It's not flashing fast, both the front and rear bulbs are fine. I'm just unsure as to what else in the system could be causing it.
1955moose
Their is a relay, but I'm not sure if it's swappable or its soldered in. Sounds like something's fused together. Usually a shorted relay doesn't work at all. Try swapping out the turn signal flasher, and go from there. Preferably a Ford dealer one, they cost a little more, but work better, without issues.
CoastieMarquis
NC
Flasher is just another term for relay... which is fine, but where is that located?
CoastieMarquis
NC
I checked the 2008 owners manual, it shows the relay for the trailer signals, and the fuse for the signals, but no actual relay for just the flash. I'm very confused.
1955moose
I believe the 3 rd gens have the signal function as part of the smart junction box, basically the more modern Gem module that came on earlier ones. It's confusing because parts stores list a relay/turn signal flasher, but theirs no where for it. My 2000 has a replacement relay under dash, driver's side. I replaced mine a few months back. Anybody else want to chime in, does he have a replacement flasher? And if so where is it?
stamp11127
Temple, Georgia
It has the new, modern razzmatazz electronic flasher in the sjb.
How are you with wiring diagrams? Easy way to test the mfs.
CoastieMarquis
NC
I myself am not great with wiring and diagrams and such. HOWEVER, I am an aircraft mechanic in the USCG and happen to know a few really good electrical/electronics guys that would be able to help me.
1955moose
Stamp that's what I thought. Harley's had the same deal. It was part of a junction box . Why then do all the parts stores show a traditional flasher? Just to mess with you! Well Coastie your not going to like this part, but if it turns out to be the junction box, and you replace it at home, your SUV won't run. Apparently the old one has to be programmed into the new one by dealer. I just read that part. You can troubleshoot it at home, but I wouldn't disconnect it. Maybe Stamp or one of the others can confirm that part.
CoastieMarquis
NC
Of course. Cant make something that the customer can deal with. Gotta earn that ford service money somehow.
1955moose
Ford should stand for fund our retirement department!
CoastieMarquis
NC
Guess I will schedule a service visit. And hope I can explain to them that it ISN'T the turn signal switch. And then be prepared to spend the $110 for the turn signal switch anyway.
stamp11127
Temple, Georgia
You haven't proven the mfs is bad - you can have multiple problems at the same time. Check the switch with a meter and signal going into/out of the sjb for the turn signals.
  • Exterior Lamps.1 2009.pdf
  • Exterior Lamps.2 2009.pdf
