Two Quick Questions
sjwelds
Kansas
So I'll keep this short.
08 Expedition EB 4x4
Question 1: What's the motorcraft part number for the rear air door actuators?
Question 2: Which one is the one that controls the air position (i.e., ceiling or floor)?
And thanks.
Bedrck47
Elizebethtown, PA
As stamp said
Also check on rockauto as they have motorcraft door actuators Depending on your wheelbase they are different part numbers
If yours is bad and needs to be replaced it may help to remove the bad door actuators and get the part number off of it You can then wire the door in the position you need it to be in while you order the part.
