Hi there,
I have the above-noted error and wonder if there is anything else i should be doing to resolve the issue.
I did get a used on off of ebay and can install it but from what i understand you need to program the new unit to the vehicle
how do i use forscan to reprogram the new module once I install it.
Forscan log below
And what would be the simplest way to remove the bumper cover there? Thanks
===IPC DTC U0534:56-0A===
Code: U0534 - Invalid Data Received From Side Obstacle Detection Control Module 'B'
Additional Fault Symptom 56):
- Invalid/Incompatible Configuration
Status (-0A):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
===END IPC DTC U0534:56-0A===
===IPC DTC U0534:82-0A===
Additional Fault Symptom 82):
- Alive/Sequence Counter Incorrect/Not Updated
Status (-0A):
===END IPC DTC U0534:82-0A===
Forscan log below
Status (-0A):
Status (-0A):
