I have an awesome 2000 Epxy with 128,000 miles on it. It's got a 6" lift kit, and it goes anywhere I need it to go.
Sadly, it appears I've blown the head gasket (or worse - warped heads, cracked engine block?). I have oil in the antifreeze, antifreeze in the oil, and when the engine warms up I get a misfire in one of the cylinders due to antifreeze getting into the piston chamber.
Just to fix the head gasket is several thousand dollars as I've been told by multiple mechanics that the engine has to be pulled in order to get access to work on it. Even at that, all the mechanics are recommending a new engine as it's most likely that I have more damage beyond the blown head gasket, and a new engine isn't that much more expensive given that the old one has to be pulled either way. The problem is that I'm not wanting to put that kind of money into a vehicle this old. I do however want to try to get this vehicle to last as long as possible before I have to replace it.
When the engine would warm up I get the misfire and the engine would start to overheat from combustion gases getting into the cooling system. I've removed the thermostat and now the engine hardly ever even gets up to normal operating temperature.
I've tried several "mechanic in a bottle products" in an attempt to at least slow the damage. They work a little, but the leaks are still there, just not as bad.
From what I understand, my car will die because of the coolant in the oil causing engine damage. Overheating is no longer an issue since pulling the thermo as I mentioned above. To help with this I'll be changing the oil more frequently and will be intentionally using non-synthetic oil in an attempt to actually have the oil help gum up the leak, at least to a minimal degree.
I'll also be intentionally using a lower quality of gasoline (I was using Shell V-Power Nitro+) in an attempt to help gum up the leak in the cylinder with the misfire as well.
My question: is there anything else I can do to help make the car last longer? Am I off with my thinking on anything I'm doing? I realize most of this stuff you shouldn't ever do to a car that you want to last a long time, but I'm just hoping to get it to last maybe another year. The longer it lasts, the more money I'll have saved up to buy a better replacement vehicle with.
Also, please don't get into "you should just put a new engine it". If I'm getting a new engine there will be a whole new car attached to it. Thanks in advance for your help with this somewhat backwards question.
Ken V.
Ken V.
