Vacation - Battery disconnect ?
Plati
I'm travelling a lot this winter, month at a time. Don't want my 2003XLT battery to run down and freeze. Battery Tender at AutoZone is $44, fughetaboutthat. Is it OK to just disconnect the battery? If I do that ... is it preferable to remove positive, negative, or both battery cables? Negative (ground looks a lot easier to remove). I've got a 3/6 amp battery charger but thats to not be used as a battery tender, right?
The Owners Manual says ... if battery is disconnected ... the transmission must relearn its shift settings, idle has to relearn, fuel trim has to relearn, and worst of all I will lose my preset radio stations. Sounds bad since everything works so well at the moment. Not sure I want to risk that.
If you've got a safe place to leave battery tender plugged in, that's the best bet. Just disconnecting a battery then rehooking it up, especially in extreme weather, you'll lose some of the charge. I think it's about 1/10th volt every 2 days. If that theory's correct, your 12.6 volt fully charged battery will be at 11.3 volts after 30 days. Personally I don't think the drop is that critical. If your just going the disconnect route, why not install one of the battery disconnects, that hooks up on the positive side of battery. Cheap to buy at any parts store, and easy to install. Owners of classic cars use them all the time.
Max Fernandez
Colombia
It is always better for your battery to go with a battery tender. My humble recommendation is to go with that.
P
Plati
Think you're right. I'll put a crowbar in my wallet and buy one. Probably can beat that AutoZone price. Then I'll have one when I need one forever.
Trainmaster
Old School Member
Rockaway Beach, NY
These cars have a bit of a drain. I store my '67 pickup all winter in an unheated garage and it starts right up in the spring. I'd put the battery tender on it if it's going to be laid up for months. For a month at a time you shouldn't have any problem if you run it every month.
Temple, Georgia
I've been using Harbor Freights battery tenders for years without issue. May be on sale now.
I would have loved to have s battery tender back in the 70's when our motorcycle batteries would be replaced pretty much every year. I think back then the quality wasn't that hot either. But yeah like we've all said, get a tender, plug it in, and like the Jersey boys say, fahget about it. Their safe, and they work.
lbv150
Northeast
Get the original Battery Tender, not an imitation. If it's any consolation, I have a permanently installed under the hood a waterproof 6 amp charger and mine gets plugged in every night.
CaptOchs
Rochester NY
Harbor Freight battery tenders are around $5-$8. They will fit inside the engine bay.
Other then that, just pull the battery and stick it in your basement.
Junker
