2001 Expedition 4.6 L.....I replaced the radiator almost two years ago. Ever since then I have had very little heat inside my Expedition. Engine comes up to temp the way it should. I have checked the blend door and it's good. I have had the flow rate into and out of the heater core and it is good. Is there a second coolant flow control somewhere in the system that could impede coolant flow. Rear heat is as bad as the front heat. I really need help with this one guys?????
