Does anyone have the part numbers for the front-most "skid plate", or should I say underside cover for the non-FX4 Expys... or do they have anything at all up front? I was getting ready to installed the base plate equipment for towing our Expy behind our motorhome when I discovered that the FX4 skid plate forward-most mount uses the frame holes that are required for the base plate. So unless I can come up with some type of way of customizing (fabricating) the two forward-most FX4 skid plate mounting brackets, I need to ditch the front FX4 skid plate. I know that's backwards going from the sturdier FX4 skid plate to the felt covered cardboard that Ford uses up front, that is, if they use one at all up front, but the integrity of the base plate that allows the 5,600 pound Expy to be pulled behind a motorhome is miles ahead of the need for the FX4 skid plate.
I know this is extra information unnecessary to this question, but for anyone who comes across this post because they want to do the same, the problem location is @ 5:20 in this video if you should happen to have the FX4 package (the video uses a F150, but the mounting is the same for the Expy):
