Water Dripping
AbbadonTD
Colorado
I got back from a 60 mile tow with the A/C on and when I got home, I parked, and a huge amount of cool water fell out. A very large amount. Should I check something? Am I building up or is this normal.
BAD RONALD
Fairfield CT
Could be the condensate drain was clogged and then cleared itself. I had a blockage on a '11 Edge that caused water to slosh around behind the dash until I cleared the line. A quart or more poured out at once.
A
AbbadonTD
Colorado
It was that much, a quart or so. I was surprised since I assumed it all dripped out as I drove. Here I am with a warm engine dripping cold water. My first thought was to check the cup holder - where I had some water.
BAD RONALD
Fairfield CT
So the water leaked inside the truck? If it did then the drain is probably still clogged. You need the get the accumulating water outside.
Check out: https://www.youtube.com/watch?v=DfXyo7a2F9A
I was able to clear the line in the Edge through a drain tube cabin connection down towards the ground and not upwards as demonstrated in the video.
A
AbbadonTD
Colorado
Nope, outside on the ground. It splashed me a little, thats how I noticed it was cool and not hot.
