Water leaking into the passenger seat (Ford 2003 Expedition)
jeremiahjw
Dallas
It seems to be coming down the grab handle on the inside of the car and leaking onto the seat/floorboard. It's something that happened after having the car for 2-3 years.
EDIT: I think it's the Eddie Bauer edition.
sgtowing
Supporting Members
Valrico, Fl
Check the weather stripping around the door for tears or rips or deterioration
Sent from my DROID BIONIC using Tapatalk
2k3Expy
Leesburg, Va
Mine hasn't done this since the windshield was replaced. I accidently put my wife's head into the windshield. Very costly repair.
J
jeremiahjw
Dallas
@Sgtowing: The first layer of rubber lining (not the one right next to the door) does have dampness in it if I pull it out a little. Is this something I can replace myself and get a good seal, and if so, how much would it cost?
dvwestmoreland
washington state
looking for help w/water leak. i have a 99 eb that has leaked somewhere around the windshield/door seal/sun roof for years. i have systematically taken apart the sunroof (cleaned/tested the drains) removed interior trim/door seals (cleaned and re-crimped/replaced) and poured water over the entire roof to see if it is coming in from the "not so obvious place" without success. this leak seems to be an issue w/the expedition and i've read countless accounts of people with the same problem, but have not located/read of a solution. it is at the point where i am starting to have electrical issues and understand that the leak may be the least of my worries if/when this happens. could use some advice if anyone has found the "smoking gun". much appreciated, dave
kevinw2345
London, Ontario, Canada
ive got water leaking in the back of the truck by the back window. I was told its because i have a crack the whole way down the rain channel on the driver side roof. Was told it is probably coming in through there.
JUST4FUN
Admin
Moderator Administrator
Il
if you have a sunroof check the drain tubes
mindgame
Honolulu, Hawaii
No sunroof? Check your roof anyways.. I had a hole in one of the slots on the roof when water pooled after rain...
gasman1149
Connecticut
I had water pouring out of the drivers side grab handle. Removed the headliner and found the moonroof drain disconnected as well as being plugged with debris where it drains down in the firewall. Reconnected hose and shot some compressed air into the drain and now it works like a charm.
BigJuicy02
Hinesville, GA
I have water coming down the grab handle, pass. side on my 99 EB. I pulled the headliner back and I can clearly watch the water coming through the windshield seal. Sounds like you probably have the same problem.
Take the sunvisor off and pull the headliner back a little and see if you can locate the leak, its a little hard on the neck. Better a windshield seal than a rust hole in the roof (which I also have on the driver side)
Doug Reed
Woodruff, WI
I tried everything with the sunroof so I used Flexseal and sealed the sunroof shut.....and it still leaks! It comes off the passenger side grab handle. I like the comment about a crack in the rain channel. I will inspect it further. I too am experiencing electrical problems.
