Weird clicking sound in passenger-side cargo area.
CubSmurf
Houston
2017 XLT, manual 3rd row, standard (small screen) Sync and I have an intermittent 'clicking' sound in the passenger side of the cargo area.
Sounds a bit like a relay clicking, but not even sure what would be back there. No error messages, nothing acting up, just an intermittent clicking.
Did a search, didn't see anything.
Anyone ever deal with this?
Hamfisted
Ft Lauderdale
Does the clicking change if you select a warmer / cooler temperature in the rear HVAC system ? Would be a bad temp blend door actuator.
MOTORCRAFT YH1856
Goofy173
Ky
Hamfisted is correct. Take the panel off and you'll find it. It's definitely the rear HVAC unit.
cmc3
Florida
I have a similar clicking, FORscan revealed, HVAC B11E3 Rear HVAC Damper motor
C
CubSmurf
Houston
Thanks for the responses, all. It did seem to make noise when I was changing temps in the rear.
