It started when we first bought the car. At first it was a draining battery every night, I just disconnected the battery every night. Found a .35A drain coming from fuse 15 on the CJB. Everything else worked on the car except the 6 disk changer and the light was on for the air suspension. Then one day we drove it for about 120 miles with a bunch of stops, turning it off and on. Got home and let it sit for 6 hours, went out to start it and nothing, no interior/foot board lights, no ding or dash lights when the key was turned. Nothing, except a clicking noise coming from the battery saver relay. I have noticed the windshield does leak. My first thought, the GEM. Got it pulled and no visible water damage at all. Even without the GEM in still a clicking noise from battery saver relay. Figure water damage in CJB. I got it out, couldn't open it without it sounding like it would break. Ilet it sit in the house for the night. I put it back in the next day and everything was back, wouldn't start still. Had a neighbor with his diesel's 2 batteries jump me. Wouldn't charge or start still, and after 3rd time of trying to start it it went back to clicking noise in battery saver relay.
I thought CJB was bad, got a used one in that had been tested. Same thing, clicking in that relay. The only thing that will make it stop is if I pull the interior light relay or the battery saver relay or if I pull either fuse 14 or 15, and if I turn the headlights on.I've tried pulling every fuse inside engine compartment and cab. I even disconnected every plug under the dash and in it, still clicks.
I found and removed a gps tracker a dealership added and it did the whole I want to run thing again. Tried starting it 3 times, and clicking came back. No lights nothing, again.
