Wint
Greetings,
I've been having this strange issue where there is a stutter or intermittent lowering of power (I have a hard time describing the feeling, it's a barely perceptible change in pull from the engine) when maintaining speed. When accelerating you don't feel it for the most part, it becomes noticeable after I've reached whatever speed I'm cruising at and I'm pressing the gas pedal just enough to maintain that speed (usually between 35-45 is where I see it, less so at interstate speeds).
After reading around the forums I'm thinking maybe I should have the codes read and see if it's an O2 sensor? Also sounds like seeing if the MAF sensor needs to be cleaned?
Any other suggestions or am I on the right track so far?
