Weird Starting Issue
Miles Walcott
North Carolina
So I go to start my truck and it doesn’t. What sounds like is happening is the starter spins and the engine wants to turn over, but it loses its engagement and stops trying to start. I connected my jump box to it and after a few more tries it did run. The moment the car cut off, the issue reoccurred. It’s to the point where if it catches and then uncatches (sorry for the wording) if I leave the key in the starting position the starter will keep going until I let off.
The link is attached to the video I recorded.
It’s weird for me, because I always thought if a starter was bad, it was not doing anything at all.
stamp11127
Temple, Georgia
At that mileage I would bench test the starter & solenoid that is on top of the starter. Sounds like the contact disc inside may have seen better days and the drive gear isn't fully engaging the ring gear.
bigdogchrisl
Fort Collins CO
Starter isn't fully firing the bendix drive to engage flywheel. You can tear it down and find out why or just replace the starter. Mostly I've seen this when vehicles starter stayed engaged after starting and it somehow fried it.
Personally, I'd just replace the starter especially if you might need the truck soon. (Guess just a sidebar on current events) plus then you could also have confidence that THOSE components wont fail in the near future.
Sent from my SM-N970U using Tapatalk
M
Miles Walcott
North Carolina
Well replaced the starter. It wasn’t as brutal as I thought. But not only did it fix the issue, somehow the power seat started working too. ‍♂️
bigdogchrisl
Fort Collins CO
[emoji2935] Nice work. Congratulations!
On both things. I'd say your seat stopped due to a bad ground, that got tightened with what you did. Or a short - but I pray it's not that. Those suck. These are known to rust, so grounds fail...
