What hose is this?
whtbronco
Winchester, VA
There's 2 vacuum lines there. If you follow both of them to the left in the picture they connect to the 4wd hub solenoid. At the solenoid the lower hose connects to the engine and the upper connects to the 4wd hubs called Integrated Wheel Ends at the front wheel bearing hubs.
The vacuum line to the engine also splits off and gores through the firewall for the HVAC system.
kstemple9
kstemple9
Virginia Beach
I need to replace it.
Thank you!
