What is the purpose of the flip-up tailgate window?
David1
Pa
May have been mentioned, sorry I'm not reading 4 pages, it Allows packing the vehicle full. Load the luggage, rifle cases, and the coolers last. Close the tailgate then open the window. There now is an easy 12" gap for beach chairs bottles boots pillows all the odd stuff. Now nothing moves while driving. Arrive at destination be sure to open glass first or the bottles fall out and break. Hmmmm
Bfountain52
I put longer items like 12’ lengths of wood trim and tie down the window for a short trip from HD, it can cause a draft inside of tailpipe exhaust... not good.
Other than that mostly it’s convenient to put a couple smaller items in and out quickly.
66nova
Fort Worth
Please forward that info to Toyota before they get someone killed.
And make that Ford too, as you can run the Expedition with the rear window WIDE open. So there's that too.
I'd also recommend you read the entire 30 year old article, and note the rarity of these incidents even at the time of publish, as well as the age and type of vehicles it is occurring in (30++ years ago).
Legit questions. With the power up and down in the toyota, does it have rear defrost? Also, can it be opened from the outside without the vehicle on?
I see the benefits in both the flip up and power down. I like the quickness and ease of access of the flip up.
David1
Pa
Legit question. With the power up and down in the toyota, does it have rear defrost?
Mine is a 2010, has defrost, and the struts hold it open while driving back from HD. I would assume the 4th gen is the same. Ford cant legally say leave it open
66nova
Fort Worth
I use my rear window pretty much daily. My 18 max will fit in the garage and I back it in, but I cannot open the tailgate. I can open the rear window open. I load my 4 kids back packs in the rear window without having to pull out (I have 4 kids, obviously that's a problem for me)
66nova
Fort Worth
On my 18 max that's how it works also. I was referring to the toyota being mentioned with the power up/down window.
3rd Expyowner123
I frequently open the window when arriving home from the grocery store to make sure when I open the hatch, groceries will not fall out the back due to groceries shifting on the way home.
aFORDable
Chicago, IL
Can anyone explain the use case for the flip-up rear window on the tailgate?
I had assumed that maybe it was for carrying really long items, but then I read that driving with it open can damage the glass or hinges.
And it can’t really be used for ventilation since it doesn’t roll down.
So what is the purpose? Do others find it useful?
Thanks!
aFORDable
Chicago, IL
This was in place for the soccer moms stack items when the back seats are used can spill items on the floor when you open the whole hatchback open. Using the flip - up rear window makes it easy to reach inside to add or remove items will not spill over. Hope this helps.
edyk1986
