Who has the most miles out of a set of spark plugs on a 3 valve 5.4,mines an 07
poppie
Wisconsin
Got 115,000 on the original plugs, still starts at the click of the key and after a trip down to Illinois got 22.82 MPG hand figured never going over 70 MPH ,the on board Lie-O-meter did get down to just over 18 MPG this winter with town and country driving but it also got down to - 20 some days, all in all I'm totally pleased with our Expy except for the paint issue on the hatch which is just starting to show with bubbles AND that Aluminum / paint issue will keep me out of a new one for that reason alone.
I’m averaging 16.0 MPG this week mostly city..... my plugs were replaced though.
mcloven
margaritaville
150k and need to change soon. runs pretty good, but i do get a miss under heavy loads sometimes. probably change them in the next few weeks.
Black
Kentucky
A contest I’ll gladly loose every time.
Plugs are cheap and get swapped every 50k in my rigs.
Don’t like the idea of fine threads heat cycling that many times especially of dealing with aluminum blocks.
gixer2000
Retrofit or Bust
Massachusetts
I see no issue with doing them frequently. Nothing wrong with staying ahead of it even if it may be a little premature. If I had the time I'd probably do them early also but I have a crazy schedule with 2 athletic teenagers and a 2 year old so I'm usually in desperate need before I can make the time
P
poppie
Wisconsin
Don’t like the idea of fine threads heat cycling that many times especially of dealing with aluminum blocks.............................Back in the old days with the old style plugs that I changed every 15,000 miles or so and when engines had cast iron blocks I would agree with you BUT with the new Platinum plugs and the SOFT aluminum blocks now days the less you screw with them the better off you will be AND how does replacing the old plugs with new plugs have anything to do with heat cycling and treads, you lost me there, And then there is that issue of the plugs occasionally breaking off while being removed, not a job for the faint of heart and that statement from a guy who in his younger days overhauled engines, https://www.carcomplaints.com/news/2016/ford-spark-plugs-breaking-lawsuit.shtml , I screwed up with this one as we were moving to another state after selling our business at retirement and also building a new home and totally forgot about it ,QUOTE ,(Some owners paid more than $1,000 to have repair facilities use special tools to remove the broken spark plugs),- If your spark plugs were replaced on or after October 23, 2015, the deadline for submitting claims is February 27, 2017.
lbv150
Northeast
'04 & '06 were changed at the recommended 100,000 miles. No problems with breakage.
Black
Kentucky
Antiseize keeps the threads in the block from fusing with the threads on the plugs.
Antisieze will breakdown over time and with more heat cycles. It is especially so with aluminum compared to iron as aluminum heats up much faster. Aluminum is also a much softer metal than iron so once the anti seize has broken down aluminum threads are more likely to fuse to the threads on the plugs.
The issues with the broken plugs generally did not occur at lower mileage interval changes.
You ran into issues as the threads began to fuse, coupled with the 2 piece plug design the added friction on the threads from longer interval changes stressed the area where the 2 parts of the plug were joined and the plug would break.
Back when copper plugs were the norm one did not see this issue as much because a copper plug won’t last nearly as long as a platinum or iridium plug and the plug would go bad and need to be changed out long before the anti seize would break down.
Gary Waugh
Princeton, TX
mine is an 08 and I changed them at 123K miles and had no issues!! Was very concerned about them possibly breaking (given all the issues others have had, but they came out no issue at all, installed the new ones with some anti-seize copper grease, so hopefully i will still own this truck when it arrives at 250K miles and I change them again!!
Gary
Trainmaster
Old School Member
Rockaway Beach, NY
Usually change mine at about 90K in both the 2000, 2008 and 2010. At that mileage, they usually look pretty nasty, but still run fine. The new ones always run better though.
Never used anti-seize on a plug. I always use a torque limiting deep socket wrench, and never had one of the ones I changed blow out.
1955moose
Only the early 2 valve motors up to about 2002 I believe, had the short thread issue. Due to that fact, if you didn't tighten enough, around 15-17 ft lbs, they would spit out like watermelon seeds. I've always liked using anti sieze. True what they say about it breaking down, but it still is better than not using it. Nothing makes your jaw drop more, than pulling a plug, that pulled the cylinder head threads with it!
Cooldog
Kenton, DE
LOL ... Last August I bought a 2010 Expedition EL 4x4 with 172K on it, from a dealer up in northern New Jersey. It ran terribly when I went to test drive it, but the price was right $5,775, so I took it anyway. I limped home for 180 miles, barely able to maintain 65mph.
In the end, it had some bad coil packs, and the plugs looked like they had NEVER been changed; the gap was just shy of TWICE what it should have been.
The O2 sensor codes it was throwing turned out to be false too; a $99 ECM update fixed the problem. I was planning to do the 3X drain and fill for the ATF, but stopped after one (and the filter) because the fluid was clearly quite clean and fresh. The transfer case fluid was another story ... looked like it had never been changed.
It runs beautifully now. The only issue left is the usual paint problem on hood and tailgate. The hood is barely noticeable, but the tailgate needs attention.
I stole it!
outdare
I changed mine at 100k in my 07 EL. I am shocked that y'all are getting such good gas mileage. I drive mostly city (think school bus) and avg 11mpg.
Sent from my SM-N920V using Tapatalk
lbv150
Northeast
My '04 averages 11-12 mpg. The '16 17-18 mpg.
Habbibie
Is it Christmas yet?
Chicago
Has same exact problem but mine was at 130k at the time before I changed them out
