Will 33 inch tires & 0 offset wheel fit on 2017 Expedition EL Limited with no rubbing ?
UTEngineer
Salt Lake City, UT
Will 275/60R20 (33 inch) tires on 0 mm offset rims fit on our stock suspension 2017 Expedition EL Limited with a stock 275/55R20 tire size (31.9”) and a stock +44 mm offset ?
Tire size is only 1 inch larger in diameter, but the offset difference also moves the wheel out almost 2 inches from the stock setup.
Appreciate any friendly feedback if you have direct experience with this combination.
