Won't start
Bronco84
Cypress
Went to get in to my expy. Turn the key nothing. Lights radio dash lights all come on. No clicking sounds like a starter problem. Checked the fuses all good there.
Any ideas would be helpful.
stamp11127
Temple, Georgia
Move the gear selector up and down while attempting to start. If that doesn't work you can jump the starter solenoid on the firewall. If you have a meter I would check the respective parts before replacement.
Bronco84
Bronco84
Cypress
Tried the gear shifter while trying to get it started. Tried jumping it and letting it sit there charging. Still nothing. Even got underneath and tapped on the starter.
f162mm
Sounds like a starter solenoid issue. Might need a new starter on this one.
f162mm
Also look for corrosion on the , solenoid and or starter connections. Also loose battery cables positive and or negative can cause this issue.
