XLT Tail lamp LED upgrade.
Lukewang01
Upstate NY
I have a 18 XLT. I really want to put led tail lamps on from the limited trim. I wonder have anyone done that and would it work? I have replaced the bulb with led and it looked OK.
Lukewang01
Lukewang01
Upstate NY
E1C76891-714A-4FC9-9919-2DEF0C1CC8D5.jpeg Doesn’t it look funny? Long story short it doesn’t work. I’m planning on playing with the electronic a little bit. There might be more posts after this.
Lukewang01
Lukewang01
Upstate NY
UPDATE #1
There are couple differences between the LED module and the Halogen module that's preventing it from working.
First is the connector type. The location of the connector fins are different between two module. The halogen ones are symmetric and the left fin on led are slightly to the right. I simply cut the left fin off so it can fit in the socket.
Second problem is with the wiring of the connectors. Halogen module uses 4 pins and LED module uses 5 pins. I assume red is power black is ground. On both module purple goes to the reverse light. During the actual testing, none of the break light on the LED module lights up when applying break or using turn signals. But when I put the car in reverse the LED pack was lit up. That was because of the different location of the wiring for the connector.
I'm going to try to change the location of the wires on the LED to see if it will light up.
Below is a diagram showing differences of the connectors. Cross means that point is not used for connection.fullsizerender(1).jpg
Lukewang01
Lukewang01
Upstate NY
UPDATE #2
Just figured out the different outputs of the connector socket. Black is ground, purple is reverse light, red is for brighter glow such as hitting the break, and yellow is for dimmer glow when turn on low beam and it stay lit. After playing around with the wiring for the LED tail lamp module, I found out that blue wire is for the led pack, red and yellow should be used for the led band around the led pack. However I can't seem to get the led band to lit up for some reasons.
There are couple possibilities to that. First is I fried the led strip during testing. Second is the computer output from the truck is different between trim levels. Third is the led is broken before I could test it given the fact that it appeared to be slightly flooded when I bought it. (All the water mark is inside the housing)IMG_2240.JPG
I actually forgot to take a video for the tail light working on the truck. I'll take a video after I sort out why the led strip is not working.
Lukewang01
Lukewang01
Upstate NY
Here's a video of the different output from the connector. Yellow line is hooked to the red wire on the connector, and blue line is hooked to the yellow wire. Sorry for the low quality of the video. I should clarify that I'm recording the driver side stock module that I changed the bulb to led and used the passenger side socket to get data. It's on hazard all the time and I pressed unlock button once to see the different output.
Lukewang01
Lukewang01
Upstate NY
UPDATE #3
Just found out why led band wouldn't work. The module I bought had some water in it. After taking the module completely apart I spotted rust on the circuit board which means this is pretty much junk, it surprises me that the led pack still works. I'm probably going to pause right here and wait till I can get my hand on another module. As I noticed on the halogen module, red wire is for bright, and yellow wire is for dim. I assume they are the same for the led band.
Also thank this LED module for the sacrifice it made in the name of "Science".
TKGracy
US
I hope this all ends up working out. The lights are one of the biggest things that i wish were different on the XLT vs the Limited.
Sent from my SM-G892A using Tapatalk
Lukewang01
Lukewang01
Upstate NY
I'm not so sure do I want to do it even if I can get it working. I don't mind shaving one of the fins off the connector, but needing to cut the wire is the deal-braker for me. There are some wiring skills needed to install it and it's not a very good idea to purchase $1200 non-refundable parts and perform some backyard-engineering on it. If someone is really smart, he can come up with some kind of connector that allows connection from a LED module to a XLT truck without needing to work on module.
browning4x4
Middle Tennessee
Anyone want to compare notes with our F150 brothers? i know to make the switch on an f150 it is a harness and housing change. Anyone have a f150 with the LED tails to take pics of plug and wire colors? i have a 15 XLT so i can provide pics of a basic taillight.... Not sure if it helps but this is an upgrade i would love to have on the epxy.
Lukewang01
Lukewang01
Upstate NY
A huge thank to Jkpinatl for hooking me up with another module.
This one seems to be in good shape, just wired it to a 10 V adapter to mess around a bit. More testing will be carried out on the car after it gets warmer here probably in a month.
Drew47000000
Daytona Beach FL
I was disappointed this wasnt plug and play. I had a LED tail lamp at my disposal today and confirmed the connector just wont fit. The LED unit looks much better but After seeing all that would go into this I think im with the guy who mentioned waiting for $100 Chinese knock offs in a year or so LOL
Lukewang01
Lukewang01
Upstate NY
Personally speaking, this car (all full size SUVs) wasn't as popular in China, F150 and Ram 1500 are much more popular. The odd of a Chinese knock off is quite small. I am hoping eventually with some soldering and wiring for the plug that I am able to just plug it into the socket and just use it.
Diverdown
KC
I wouldn’t buy anything Chinese right now!
