BEFORE ALL THAT:
Pop trunk
Look on driver side rear trim panel (trunk area/behind third row)
Pry off the trim panel marked "Fuel Reset"
Press and hold switch inside for several seconds
Try starting the truck
You need to remove the starter and have it tested.
Really????? Did you read this thread His problem isn't fuel related It a problem with the starter motor
