2003 XLT. Poked at my "rocker panels" a bit, this fell down. Can see all the way through to underside of Expy now. Wheel wells don't look much better. Need to understand how to prevent this in my 2014. It doesn't rust from the outside, rusts from inside. And they put big holes on inside to collect water & salt brine? And the paint on inside of "rocker panel" is not real impressive!!
Change my name to MrRust?
How long has Fluid Film been used on your Expy? Do you spray it inside those big holes on inside of rockers? Reason I ask is because if you have sprayed well since new ... and still rusts?My wheel well was starting to bubble in that area and I promptly had my body shop cut out all that steel and weld in new, looks good now $600 well spent. I’d say take it to krown or spray it with fluid film. I use fluid film on mine.
My truck needs new rocker panels, thanks WNY salt.
