mdntblu
Posting the following in case it helps someone else.
I kept getting an error message that the installation failed, that it ran out of disk space or does not work with this version. This is after a Master Reset, formatting the 128GB SD card as exFAT, and using the Sync update from owners.ford.com. As a test, I tried the Nav version so kindly provided by LokiWolf next and that resulted in the same error message.
I went online in a chat with Ford's Sync support to see if they could help me, and she told me to use a 32GB USB stick. I had tried the 128GB stick because (a) I couldn't find one of 32GB and (b) more storage has to be better, right? Well, I found a 32GB stick, formatted it, copied the update to it and it worked. My Expy is now updated to V2.2.
So the moral of the story is:
- Use a 32GB USB stick for the upgrade, as the unit seems to have problems reading larger sizes.
I was getting that same error and was finding that it wasn't about the size of the flash drive it was the type of flash drive. If it was USB 3.0 it seemed to not work but a USB 2.0 Flash drive worked just fine.
