I just went outside and checked and yes, mine is the 2.0 version. I tend to shy away from software or firmware updates before I can read the notes that usually accompany them...too many times I've read where people lost functionality with newer versions that they once had.
A quick search revealed these comments on various ford vehicles:
"There don't seem to be a lot of changes, other than as a whole the unit seems snappier, and the right side LCD display next to the speedometer is now displaying info from bluetooth sources."
It works. I did it about a month ago. Android Auto works well, especially the navigation with traffic and the voice recognition and destination searching is far superior. Can send text messages via the voice interface as well. On the sync3 navigation the speed limit shows up larger and more clearly which is nice.
Here is the change log for the 2.2 update from the 2gfusions post:
So I tried the update and got to 2.2, but now I can't change radio presets either by touchscreen or the steering controls. I did a master reset twice to no avail. I'm off to the dealer tomorrow for them to resolve it and an oil change.
So it looks like the update looses the use of radio presets, adds Android Auto which does not allow the use any interesting apps, just gives you a sexier voice. Anybody found anything of value in this update. Make sure your phone will install Android Auto before updating. Can I go back to an earlier version.
BACKGROUND
Many of us who bought a 2016 model with Sync 3 are still on v. 1.0. As it turns out, there is a
v2.2 that has been leaked to the public (presumably originally by a Ford employee) last December. This is the same Sync 3 update that many folks have used to update their F150’s, Fusions, and Mustangs. Many Transit owners at this point have done so as well. Other models have started to have v2.2 show up through the automatic wifi updates. But it appears that no Transit has so far. Thus, many of us are going ahead and manually updating using a file downloaded onto a
USB flash drive. It’s not clear why Ford hasn’t released it to everyone through the normal update process. It seems that there are few or no bugs with a proper install.
There are two main advantages of updating to
v2.2: Android Auto and Apple CarPlay. If you don’t want to wait for these improvements, go for it. There are a few other software refinements also. If you want to use Apple CarPlay, you also have to replace the lower USB port (hub) with a newer version costing about $50 - $70. Installation of the port is easy. Downloading the files onto a USB and getting Sync updated is more challenging but went smoothly once I figured out which files to use.
See other instructions online if your Sync 3 is not the version with navigation, or if you don’t have a North American model, or if you aren’t running 1.0 or 1.1. And if you have a 2017, you should already have an updated system.
Change Log:
Sync 3 2.2.6
This software release is the latest update in our continued efforts to improve system performance, device connectivity, and the overall SYNC experience.
This software contains the following enhancements:
- Updated voice recognition engine.
- Bluetooth phone, media, and Wi-Fi improvements.
- Navigation user interface improvements (if equipped).
- Android Auto for supported devices.
- Apple CarPlay for supported devices. Owners of 2016 models with SYNC 3 are required to perform a software upgrade and purchase a hardware upgrade through your dealer.
The installation of this update will take up to 60 minutes to complete. DO NOT remove your USB drive or turn off your vehicle. You must wait until Installation Complete is displayed on the center screen before removing your drive or turning your vehicle off. Be sure your vehicle engine is running (not in accessory mode) throughout the entire installation process. Although your vehicle must be in park when you initiate the installation process, once the download process has begun, you may drive your vehicle.
I'm good with my 2.0...other than the voice control defaulting to turning the heat on HI when if fails to understand ENGLISH<LOL>..it's alright.
jeff
