Ken W
I ran them on my Pathfinder & F-250. No complaints & never noticed any additional brake dust.
Overkill for a 6000 lb pig that I tow with? No such thing as overkill considering the weight imo
Did you follow the break in procedure?I have them and I wouldn't buy them again. They aren't any better than stock. I'm on my second set of powerstop rotors up front. I thought the first set warped somehow so I replaced them. What I thought was warped was the plating coming off the rotors in chunks. My 2 cents.
I have experienced fade while pulling my car trailer however they were on aftermarket pads/OE rotors. I also dont know if it was fluid fade or friction fade so I figured I'd give these a shot. Drilled/slotted completely changed the way my grand prix and mustang stopped so why not see how it affects this pig.What exactly do you think you’re gaining with these over stock? They look better then plain solid rotors I’ll give you that. Them being slotted and drilled won’t benefit you in any way whatsoever. I highly doubt you’ve ever used your oem brakes so hard that you’ve experienced fading from heat. I tow a 9000lb toy hauler regularly and have never experienced brake fade and there’s been a few times I’ve had to slam on the brakes pretty hard.
Heat is what makes your brakes work better
I have slotted and drilled rotors on my CTSV with Hawk HPS 5.0 pads and it took multiple laps around a track and multiple heavy braking scenarios from 140 down to 30mph for them to heat up and experience any fade.
Plan on taking your Expy to the track? Lol!
In your situation it’s the pad that is going to improve your braking. Not fancy looking rotors.
With that said it’s your cash spend it how you want. Better braking performance could have been attained with just a better pad and solid rotors though. But with you being an optometrist, electrician and lighting expert. I’m sure your some how an expert when it comes to brakes to.
I am anxious to see what they look like though
I don't know about you guy's, but theirs no such thing as too much brake. My first edition has tiny front rotors for the weight and wheel size its stopping. Heat is the enemy of any item on these vehicles. True you want some heat and friction to stop, you wouldn't want air conditioned rotors. That being said, repeated applying of brakes, extra weight from trailers, stopping/slowing on long downhill grades, is murder on pads/rotors. Anytime you can dissipate heat, that's a good thing. Cleaning brake dust, come on, are you really that lazy! You'll work on your truck all weekend, but won't spray some wheel cleaner, and old sponge to clean brake dust. Buy an old 1960's truck with 4 wheel drum brakes if you don't want wheel dust. From what you guys said, sounds like more positive, than negative posts for these bargain rotors!
